Complexity of control-affine motion planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2015
In this paper we study the complexity of the motion planning problem for control- affine systems. Such complexities are already defined and rather well-understood in the particular case of nonholonomic (or sub-Riemannian) systems. Our aim is to generalize these notions and results to systems with a drift. Accordingly, we present various definitions of complexity, as functions of the curve that is approximated, and of the precision of the approximation. Due to the lack of time- rescaling invariance of these systems, we consider geometric and parametrized curves separately. Then, we give some asymptotic estimates for these quantities. As a byproduct, we are able to treat the long time local controllability problem, giving quanti- tative estimates on the cost of stabilizing the system near a non-equilibrium point of the drift.
hal-00909748 , version 1 (26-11-2013)
Frédéric Jean, Dario Prandi. Complexity of control-affine motion planning. SIAM Journal on Control and Optimization, 2015, 53 (2), pp.816-844. ⟨10.1137/130950793⟩. ⟨hal-00909748⟩
404 Consultations
0 Téléchargements
