Types for controlling heap and stack in Java - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A type system is introduced for a strict but expressive subset of Java in order to infer resource upper bounds on both the heap-space and the stack-space requirements of typed programs. This type system is inspired by previous works on Implicit Computational Complexity, using tiering and non-interference techniques. The presented methodology has several advantages. First, it provides explicit polynomial upper bounds to the programmer, hence avoiding OutOfMemory and StackOverFlow errors. Second, type checking is decidable in linear time. Last, it has a good expressivity as it analyzes most object oriented features like overload, inheritance, and also handles flow statements controlled by objects.
ObjectIsBeautiful.pdf (434.17 Ko) Télécharger le fichier
hal-00910166 , version 1 (27-11-2013)
  • HAL Id : hal-00910166 , version 1
Emmanuel Hainry, Romain Péchoux. Types for controlling heap and stack in Java. Third International Workshop on Foundational and Practical Aspects of Resource Analysis (FOPARA), Ugo Dal Lago and Ricardo Pena, Aug 2013, Bertinoro, Italy. ⟨hal-00910166⟩
216 Consultations
82 Téléchargements
