Case-based Reasoning : Foundational Issues, Methodological Variations, and System Approaches. AI Communications, pp.39-59, 1994. ,
Abstract, The Journal of Symbolic Logic, vol.48, issue.02, pp.510-530, 1985. ,
DOI : 10.1080/00048408412341331
REVISOR : un ensemble de moteurs d'adaptation de cas par révision des croyances, Journée Intelligence Artificielle Fondamentale, 2013. ,
Belief Merging-Based Case Combination, Case-Based Reasoning Research and Development, pp.105-119, 2009. ,
DOI : 10.1007/3-540-60598-3_9
URL : https://hal.archives-ouvertes.fr/inria-00421724
An Algorithm for Adapting Cases Represented in an Expressive Description Logic, International Conference on Case-Based Reasoning (ICCBR), LNAI 6176, 2010. ,
DOI : 10.1007/978-3-642-14274-1_6
URL : https://hal.archives-ouvertes.fr/inria-00506078
Belief revision-based case-based reasoning, Proceedings of the ECAI-2012 Workshop SAMAI : Similarity and Analogy-based Methods in AI, pp.33-39 ,
DOI : 10.1007/978-3-642-54516-0_6
URL : https://hal.archives-ouvertes.fr/hal-00763220
Diverse Plan Generation by Plan Adaptation and by First-Principles Planning: A Comparative Study, Case-Based Reasoning Research and Development (ICCBR), LNCS 7466, 2012. ,
DOI : 10.1007/978-3-642-32986-9_5
On the complexity of propositional knowledge base revision, updates, and counterfactuals, Artificial Intelligence, vol.57, issue.2-3, pp.227-270, 1992. ,
DOI : 10.1016/0004-3702(92)90018-S
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
DOI : 10.1016/0004-3702(91)90069-V
Merging Information Under Constraints: A Logical Framework, Journal of Logic and Computation, vol.12, issue.5, pp.773-808, 2002. ,
DOI : 10.1093/logcom/12.5.773
Application of the Revision Theory to Adaptation in Case-Based Reasoning: The Conservative Adaptation, International Conference on Case-Based Reasoning (ICCBR), LNCS 4626, 2007. ,
DOI : 10.1007/978-3-540-74141-1_17
URL : https://hal.archives-ouvertes.fr/inria-00189626
Amalgam-Based Reuse for Multiagent Case-Based Reasoning, 19th International Conference on Case Based Reasoning -ICCBR'2011, pp.122-136, 2011. ,
DOI : 10.1007/978-3-642-23291-6_11
Reformulation in case-based reasoning, European Workshop on Case-Based Reasoning, EWCBR-98, pp.172-183, 1998. ,
DOI : 10.1007/BFb0056331
Towards Case-Based Adaptation of Workflows, International Conference on Case-Based Reasoning, pp.421-435, 2007. ,
DOI : 10.1007/978-3-642-14274-1_31
Heuristics ? Intelligent Search Strategies for Computer Problem Solving, 1984. ,
Belief Revision, Handbook of Knowledge Representation, pp.317-359, 2008. ,
Inside Case-Based Reasoning, 1989. ,
Opponent Type Adaptation for Case-Based Strategies in Adversarial Games, Case- Based Reasoning Research and Development (ICCBR), pp.357-368, 2012. ,
DOI : 10.1007/978-3-642-32986-9_27
From Inconsistency to Consistency: Knowledge Base Revision by Tableaux Opening, Advances in Artificial Intelligence (IBERAMIA), pp.120-132, 2010. ,
DOI : 10.1007/978-3-642-16952-6_13
Optimizing the clausal normal form transformation, Journal of Automated Reasoning, vol.16, issue.4, pp.325-336, 1991. ,
DOI : 10.1007/BF00249017
