HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Semi-Autonomous Haptic Teleoperation Control Architecture of Multiple Unmanned Aerial Vehicles
Abstract : We propose a novel semi-autonomous haptic tele- operation control architecture for multiple unmanned aerial vehicles (UAVs), consisting of three control layers: 1) UAV control layer, where each UAV is abstracted by, and is controlled to follow the trajectory of, its own kinematic Cartesian virtual point (VP); 2) VP control layer, which modulates each VP's motion according to the teleoperation commands and local artificial potentials (for VP-VP/VP-obstacle collision avoidance and VP-VP connectivity preservation); and 3) teleoperation layer, through which a single remote human user can command all (or some) of the VPs' velocity while haptically perceiving the state of all (or some) of the UAVs and obstacles. Master-passivity/slave-stability and some asymptotic performance measures are proved. Experimental results using four custom-built quadrotor-type UAVs are also presented to illustrate the theory.
Document type :
Journal articles
Complete list of metadata
Cited literature [43 references]  Display  Hide  Download
https://hal.inria.fr/hal-00910801
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Thursday, November 28, 2013 - 11:35:49 AM
Last modification on : Thursday, January 20, 2022 - 4:20:28 PM
Long-term archiving on: : Monday, March 3, 2014 - 5:31:04 PM
File
2013_ieeetmech_lee.pdf
Identifiers
Citation
Dongjun Lee, Antonio Franchi, Hyoung Il Son, Changsu Ha, Heinrich H Bülthoff, et al.. Semi-Autonomous Haptic Teleoperation Control Architecture of Multiple Unmanned Aerial Vehicles. IEEE/ASME Transactions on Mechatronics, Institute of Electrical and Electronics Engineers, 2013, 18 (4), pp.1334-1345. ⟨10.1109/TMECH.2013.2263963⟩. ⟨hal-00910801⟩
Share
Metrics
Record views
389
Files downloads
701
