Journal articles
Improvement of satellite conflict prediction reliability through use of the adaptive splitting technique
Abstract : Collision between satellites and debris is a rare event but with high financial consequences. This risk therefore has to be addressed carefully. To support the decision to start a collision avoidance maneuver, a dedicated tool to characterize the risk uncertainty is the probability of collision between the debris and the satellite. Crude Monte Carlo could be a way if it could cope with very small probabilities, say 10^-6, within the available simulation budget and time. The methodology nowadays in use is a numerical integration made tractable by physical hypothesis and numerical approximation. We advocate the adaptive splitting technique, presented in Cérou et al. (2007), as it avoids all the hypothesis needed for the numerical integration and clearly outperforms Crude Monte Carlo with respect to rare events. A direct comparison between Crude Monte Carlo and adaptive splitting technique approach is also given on real-life examples.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00911424
Contributor : Francois Le Gland Connect in order to contact the contributor
Submitted on : Friday, November 29, 2013 - 11:16:34 AM
Last modification on : Friday, May 20, 2022 - 9:04:52 AM
Links full text
Identifiers
Citation
Rudy Pastel, Jérôme Morio, François Le Gland. Improvement of satellite conflict prediction reliability through use of the adaptive splitting technique. Proceedings of the Institution of Mechanical Engineers, Part G: Journal of Aerospace Engineering, SAGE Publications, 2014, 228 (1), pp.77-85. ⟨10.1177/0954410012467725⟩. ⟨hal-00911424⟩
Share
Metrics
Record views
325
