New interface
Journal articles
A generalized formulation of the Linear Sampling Method with exact characterization of targets in terms of farfield measurements
Abstract : We propose and analyze a new formulation of the Linear Sampling Method that uses an exact characterization of the targets shape in terms of the so-called farfield operator (at a fixed frequency). This characterization is based on constructing nearby solutions of the farfield equation using minimizing sequences of a least squares cost functional with an appropriate penalty term. We first provide a general framework for the theoretical foundation of the method in the case of noise-free and noisy measurements operator. We then explicit applications for the case of inhomogeneous inclusions and indicate possible straightforward generalizations. We finally validate the method through some numerical tests and compare the performances with classical LSM and the factorization methods.
Document type :
Journal articles
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-00911692
Contributor : Houssem Haddar Connect in order to contact the contributor
Submitted on : Tuesday, December 3, 2013 - 4:45:06 PM
Last modification on : Wednesday, August 24, 2022 - 9:40:06 AM
Long-term archiving on: : Monday, March 3, 2014 - 10:07:07 PM
File
ArticlevIP_LA.pdf
Identifiers
Collections
Citation
Lorenzo Audibert, Houssem Haddar. A generalized formulation of the Linear Sampling Method with exact characterization of targets in terms of farfield measurements. Inverse Problems, 2014, 30 (035011), ⟨10.1088/0266-5611/30/3/035011⟩. ⟨hal-00911692⟩
Share
Metrics
Record views
479
Files downloads
587
