Software pipelining, ACM Computing Surveys, vol.27, issue.3, pp.367-432, 1995. ,
DOI : 10.1145/212094.212131
A low-power VLIW processor for 3GPP-LTE complex numbers processing, 2011 Design, Automation & Test in Europe, pp.1-6, 2011. ,
DOI : 10.1109/DATE.2011.5763048
A 477mW NoC-based digital baseband for MIMO 4G SDR, 2010 IEEE International Solid-State Circuits Conference, (ISSCC), pp.278-279, 2010. ,
DOI : 10.1109/ISSCC.2010.5433920
Instruction Assignment for Clustered VLIW DSP Compilers: A New Approach, HP Laboratories Technical Report HPL, 1998. ,
Bulldog: A Compiler for VLIW Architectures, p.8600982, 1985. ,
Optimal vs. heuristic integrated code generation for clustered VLIW architectures, Proceedings of the 11th international workshop on Software & compilers for embedded systems, SCOPES '08, pp.11-20, 2008. ,
DOI : 10.1145/1361096.1361099
Address generation for array access based on modulus m counters, Proceedings of the European Conference on Design Automation., 1991. ,
DOI : 10.1109/EDAC.1991.206373
Compiler and Architectural Techniques for Improving the Effectiveness of VLIW Compilation ,
Programming Languages -C -Extensions to Support Embedded Processors, 2006. ,
ASIP design methodologies: survey and issues, VLSI Design 2001. Fourteenth International Conference on VLSI Design, p.76, 2001. ,
DOI : 10.1109/ICVD.2001.902643
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.19.1875
BOF: Instruction Scheduling for Superscalar and VLIW Platforms. Temporal Perspective, LLVM Developers' Meeting, 2012. ,
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004., 2004. ,
DOI : 10.1109/CGO.2004.1281665
Address calculation for retargetable compilation and exploration of instruction-set architectures, Design and Automation Conference (DAC '96), 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-00008023
Loop induction variable canonicalization in parallelizing compilers, Proc. of the 1996 Conference on Parallel Architectures and Compilation Techniques (PACT'96) ,
Code Generation for Embedded Processors. Kluwer Register Allocation in LLVM 3.0. LLVM Developers' Meeting Unified Assign and Schedule: A New Approach to Scheduling for Clustered Register File Microarchitectures, Proceedings of the 31st annual ACM/IEEE international symposium on Microarchitecture, MICRO 31, pp.308-315, 1995. ,
Register Pointer Architecture for Efficient Embedded Processors, 2007 Design, Automation & Test in Europe Conference & Exhibition, pp.600-605, 2007. ,
DOI : 10.1109/DATE.2007.364659
Linear scan register allocation, ACM Transactions on Programming Languages and Systems, vol.21, issue.5, pp.895-913, 1999. ,
DOI : 10.1145/330249.330250
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.27.2462
Induction Variable Analysis with Delayed Abstractions, HiPEAC), number 3793, pp.218-232, 2005. ,
DOI : 10.1007/11587514_15
URL : https://hal.archives-ouvertes.fr/hal-01257294
Smart Register Files for High-Performance Microprocessors, 1999. ,
The TM3270 Media-Processor, 38th Annual IEEE/ACM International Symposium on Microarchitecture (MICRO'05), pp.12-342, 2005. ,
DOI : 10.1109/MICRO.2005.35
Beyond induction variables, PLDI'92, pp.162-174, 1992. ,
DOI : 10.1145/143103.143131
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.48.1292
Two-level Hierarchical Register File Organization for VLIW Processors, Proceedings of the 33rd annual ACM/IEEE international symposium on Microarchitecture, pp.137-146, 2000. ,
Bit-level optimization for high-level synthesis and FPGA-based acceleration, Proceedings of the 18th annual ACM/SIGDA international symposium on Field programmable gate arrays, FPGA '10, 2010. ,
DOI : 10.1145/1723112.1723124
