Time discretization of the Zakai equation for diffusion processes observed in correlated noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics and Stochastics Reports Année : 1991
A time discretization scheme is provided for the Zakai equation, a stochastic PDE which gives the conditional density of a diffusion process observed in white-noise. The case where the observation noise and the state noise are correlated, is considered. The numerical scheme is based on a Trotter-like product formula, which exhibits prediction and correction steps, and for which an error estimate of order δ is proved, where δ is the time discretization step. The correction step is associated with a degenerate second-order stochastic PDE, for which a representation result in terms of stochastic characteristics has been proved by Krylov and Rozovskii and by Kunita. A discretization scheme is then provided to approximate these stochastic characteristics. Under the additional assumption that the correlation coefficient is constant, an error estimate of order √δ is proved for the overall numerical scheme. This has been proved to be the best possible error estimate by Elliott and Glowinski.
Fichier non déposé
hal-00912048 , version 1 (02-12-2013)
Patrick Florchinger, François Le Gland. Time discretization of the Zakai equation for diffusion processes observed in correlated noise. Stochastics and Stochastics Reports, 1991, 35 (4), pp.233-256. ⟨10.1080/17442509108833704⟩. ⟨hal-00912048⟩
127 Consultations
0 Téléchargements
