Conference papers
Time discretization of continuous time filters for HMM parameters estimation
Abstract : We propose numerical techniques for parameter estimation of fast-sampled homogeneous Markov chains observed in white Gaussian noise. Recently, continuous-time filters that estimate the quantities used in the EM algorithm for MLE parameter estimation were obtained by Elliott. Our numerical work is based on the robust discretization of these filters. The advantage of using filters in the EM algorithm is that they have negligible memory requirements; indeed, independent of the number of observations. In comparison, standard discrete time EM algorithms (Baum-Welch re-estimation equations) are based on smoothers and require the use of the forward-backward algorithm, which is a fixed-interval algorithm and has memory requirements proportional to the number of observations. Although the computational complexity of our filters at each time instant is 0(N^4) (for a N state Markov chain) compared to O(N^2) for the forward-backward scheme, the filters are suitable for parallel implementation. A careful analysis of our techniques might reduce the computational complexity. We present simulations to illustrate the satisfactory performance of our algorithms.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00912053
Contributor : Francois Le Gland Connect in order to contact the contributor
Submitted on : Friday, December 20, 2013 - 7:20:53 PM
Last modification on : Friday, February 4, 2022 - 3:11:37 AM
Identifiers
Collections
Citation
Matthew R. James, Vikram Krishnamurthy, François Le Gland. Time discretization of continuous time filters for HMM parameters estimation. Proceedings of the 31st IEEE Conference on Decision and Control, Tucson 1992, IEEE--CSS, Dec 1992, Tucson, United States. pp.3305--3310, ⟨10.1109/CDC.1992.371026⟩. ⟨hal-00912053⟩
Share
Metrics
Record views
180
