Conference papers
Small noise asymptotics of the Bayesian estimator in nonidentifiable nonlinear regressions
Marc Joannides 1 François Le Gland 1
1 SIGMA2 - Signal, models, algorithms
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : We study the asymptotic behaviour of the Bayesian estimator for a deterministic signal in additive Gaussian white noise, in the case where the set of minima of the Kullback--Leibler information is a submanifold of the parameter space. This problem includes as a special case the study of the asymptotic behaviour of the nonlinear filter, when the state equation is noise-free, and when the limiting deterministic system is non-observable. We present a practical example where this situation occurs. We give an explicit expression of the limit, as the noise intensity goes to zero, of the posterior probability distribution of the parameter, and we study the rate of convergence.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00912061
Contributor : Francois Le Gland Connect in order to contact the contributor
Submitted on : Friday, December 20, 2013 - 5:58:54 PM
Last modification on : Friday, February 4, 2022 - 3:21:54 AM
Identifiers
  • HAL Id : hal-00912061, version 1
Citation
Marc Joannides, François Le Gland. Small noise asymptotics of the Bayesian estimator in nonidentifiable nonlinear regressions. Proceedings of the 2nd Portuguese Conference on Automatic Control, Porto 1996, APCA, Sep 1996, Porto, Portugal. pp.257-261. ⟨hal-00912061⟩
Share
Metrics
Record views
209
