Multi―sensor fusion for localization. Concept and simulation results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper presents the simulation results of a hybrid positioning system based on a pedestrian navigation system that takes advantage of very few measurements of different types as well as map constraints. The data fusion is achieved at infrastructure and user level. Particle and extended Kalman filters are implemented and tested against different beacon density scenarios. Results show that metric accuracy (below 3 meters) is achievable in structured areas of low beacons and WiFi AP density.
Fichier non déposé
hal-00912064 , version 1 (02-12-2013)
  • HAL Id : hal-00912064 , version 1
Damien Kubrak, François Le Gland, Liyun He, Yann Oster. Multi―sensor fusion for localization. Concept and simulation results. Proceedings of the 2009 ION Conference on Global Navigation Satellite Systems, Savannah 2009, ION, Sep 2009, Savannah, United States. pp.767-777. ⟨hal-00912064⟩
253 Consultations
0 Téléchargements
