Stability and approximation of nonlinear filters using the Hilbert metric, and applications to particle filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
The stability of the optimal filter w.r.t. its initial condition and w.r.t. the model, is studied in a general hidden Markov model using the Hilbert projective metric. These stability results are then used to prove the uniform convergence of the interacting particle filter to the optimal filter, as the number of particles goes to infinity.
Fichier non déposé
hal-00912083 , version 1 (01-12-2013)
François Le Gland, Nadia Oudjane. Stability and approximation of nonlinear filters using the Hilbert metric, and applications to particle filters. Proceedings of the 39th Conference on Decision and Control, Sydney 2000, IEEE--CSS, Dec 2000, Sydney, Australia. pp.1585-1590, ⟨10.1109/CDC.2000.912086⟩. ⟨hal-00912083⟩
225 Consultations
0 Téléchargements
