Test Generation and Evaluation from High-Level Properties for Common Criteria Evaluations -- The TASCCC Testing Tool
Abstract : In this paper, we present a model-based testing tool resulting from a research project, named TASCCC. This tool is a complete tool chain dedicated to property-based testing in UML/OCL, that integrates various technologies inside a dedicated Eclipse plug-in. The test properties are expressed in a dedicated language based on property patterns. These properties are then used for two purposes. First, they can be employed to evaluate the relevance of a test suite according to specific coverage criteria. Second, it is possible to generate test scenarios that will illustrate or exercise the property. These test scenarios are then unfolded and animated on the Smartesting's Certify It model animator, that is used to filter out infeasible sequences. This tool has been used in industrial partnership, aiming at providing an assistance for Common Criteria evaluations, especially by providing test generation reports used to show the link between the test cases and the Common Criteria artefacts.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/hal-00912639
Contributor : Frédéric Dadeau <>
Submitted on : Monday, December 2, 2013 - 2:21:03 PM
Last modification on : Friday, February 1, 2019 - 6:46:02 PM
Identifiers
Citation
Frédéric Dadeau, Kalou Cabrera Castillos, Yves Ledru, Taha Triki, German Vega, et al.. Test Generation and Evaluation from High-Level Properties for Common Criteria Evaluations -- The TASCCC Testing Tool. ICST 2013 - IEEE 6th International Conference on Software Testing, Verification and Validation, Yves Le Traon, Mar 2013, Luxembourg, Luxembourg. pp.431-438, ⟨10.1109/ICST.2013.60⟩. ⟨hal-00912639⟩
Share
Metrics
Record views
628
