Multi-level Modeling as a Society of Interacting Models
We propose to consider a multi-level representation from a multi-modeling point of view. We define a framework to better specify the concepts used in multi-level modeling and their relationships. This framework is implemented through the AA4MM meta-model, which benefits from a middleware layer. This meta-model uses the multi-agent paradigm to consider a multi-model as a society of interacting models. We extend this meta-model to consider multi-level modeling and present a proof of concept of a collective motion example where we show the ability of this approach to rapidly change from one pattern of interaction to another one by reusing some of the meta-model's components.
Modélisation et simulation
Multi-level-Modeling-as-a-Society-of-Interacting-Models-Technical-Report.pdf (1.21 Mo)
Télécharger le fichier
