Impact of flow-level dynamics on QoE of video streaming in wireless networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yuedong Xu
  • Fonction : Auteur
  • PersonId : 892784
Rachid El-Azouzi
The Quality of Experience (QoE) of streaming service is often degraded by frequent playback interruptions. To mitigate the interruptions, the media player prefetches streaming contents before starting playback, at a cost of delay. We study the QoE of streaming from the perspective of flow dynamics. First, a framework is developed for QoE when streaming users join the network randomly and leave after downloading completion. We compute the distribution of prefetching delay using partial differential equations (PDEs), and the probability generating function of playout buffer starvations using ordinary differential equations (ODEs). Second, we extend our framework to characterize the throughput variation caused by opportunistic scheduling at the base station in the presence of fast fading. Our study reveals that the flow dynamics is the fundamental reason of playback starvation. The QoE of streaming service is dominated by the average throughput of opportunistic scheduling, while the variance of throughput has very limited impact on starvation behavior.
yuedong-infocom_2013.pdf (330.11 Ko) Télécharger le fichier
hal-00913207 , version 1 (08-12-2013)
Yuedong Xu, Salah Eddine Elayoubi, Eitan Altman, Rachid El-Azouzi. Impact of flow-level dynamics on QoE of video streaming in wireless networks. IEEE INFOCOM - 32nd International Conference on Computer Communications, Apr 2013, Turin, Italy. pp.2715-2723, ⟨10.1109/INFCOM.2013.6567080⟩. ⟨hal-00913207⟩
333 Consultations
423 Téléchargements
