Learning Convex Combinations of Continuously Parameterized Basic Kernels, Learning Theory, pp.338-352, 2005. ,
DOI : 10.1007/11503415_23
Combining graph laplacians for semi-supervised learning, NIPS, 2005. ,
Spectral Graph Theory, 1997. ,
DOI : 10.1090/cbms/092
Random-Walk Computation of Similarities between Nodes of a Graph with Application to Collaborative Recommendation, IEEE Transactions on Knowledge and Data Engineering, vol.19, issue.3, pp.355-369, 2007. ,
DOI : 10.1109/TKDE.2007.46
A Novel Way of Computing Similarities between Nodes of a Graph, with Application to Collaborative Recommendation, The 2005 IEEE/WIC/ACM International Conference on Web Intelligence (WI'05), pp.550-556, 2005. ,
DOI : 10.1109/WI.2005.9
Multiple kernel learning algorithms, J. Mach. Learn. Res, vol.12, pp.2211-2268, 2011. ,
A graph based framework for multi-task multiview learning, ICML, 2011. ,
Resistance distance, Journal of Mathematical Chemistry, vol.69, issue.1, pp.81-95, 1993. ,
DOI : 10.1007/BF01164627
Graph Nodes Clustering Based on the Commute-Time Kernel, PAKDD, pp.1037-1045, 2007. ,
DOI : 10.1007/978-3-540-71701-0_117
A tutorial on spectral clustering, Statistics and Computing, vol.21, issue.1, pp.395-416, 2007. ,
DOI : 10.1007/s11222-007-9033-z
Getting lost in space: Large sample analysis of the commute distance, NIPS, 2010. ,
The pagerank citation ranking: Bringing order to the web, 1999. ,
The Moore?Penrose inverse of a semi-magic square is semi-magic, International Journal of Mathematical Education in Science and Technology, vol.31, issue.4, pp.624-629, 2001. ,
DOI : 10.1080/713816465
A new analysis of co-training, ICML, pp.1135-1142, 2010. ,
Learning with local and global consistency, Advances in Neural Information Processing Systems 16, 2003. ,
Spectral clustering and transductive learning with multiple views, Proceedings of the 24th international conference on Machine learning, ICML '07, pp.1159-1166, 2007. ,
DOI : 10.1145/1273496.1273642
Learning from labeled and unlabeled data on a directed graph, Proceedings of the 22nd international conference on Machine learning , ICML '05, pp.1036-1043, 2005. ,
DOI : 10.1145/1102351.1102482
Learning with hypergraphs: Clustering, classification, and embedding, NIPS, pp.1601-1608, 2006. ,
Co-ranking Authors and Documents in a Heterogeneous Network, Seventh IEEE International Conference on Data Mining (ICDM 2007), pp.739-744, 2007. ,
DOI : 10.1109/ICDM.2007.57
Learning multiple graphs for document recommendations, Proceeding of the 17th international conference on World Wide Web , WWW '08, pp.141-150, 2008. ,
DOI : 10.1145/1367497.1367517
Semi-supervised learning using gaussian fields and harmonic functions, ICML, pp.912-919, 2003. ,
