Nonparametric multiple change point estimation in highly dependent time series - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
(1) , (1)
1
Given a heterogeneous time-series sample, it is required to find the points in time (called change points) where the probability distribution generating the data has changed. The data is assumed to have been generated by arbitrary, unknown, stationary ergodic distributions. No modeling, independence or mixing are made. A novel, computationally efficient, nonparametric method is proposed, and is shown to be asymptotically consistent in this general framework; the theoretical results are complemented with experimental evaluations.
Not file
Dates and versions
hal-00913250 , version 1 (03-12-2013)
Identifiers
  • HAL Id : hal-00913250 , version 1
Cite
Azadeh Khaleghi, Daniil Ryabko. Nonparametric multiple change point estimation in highly dependent time series. Proc. 24th International Conf. on Algorithmic Learning Theory (ALT'13), 2013, Singapore, Singapore. pp.382-396. ⟨hal-00913250⟩
71 View
0 Download
Share
