Nonparametric multiple change point estimation in highly dependent time series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Given a heterogeneous time-series sample, it is required to find the points in time (called change points) where the probability distribution generating the data has changed. The data is assumed to have been generated by arbitrary, unknown, stationary ergodic distributions. No modeling, independence or mixing are made. A novel, computationally efficient, nonparametric method is proposed, and is shown to be asymptotically consistent in this general framework; the theoretical results are complemented with experimental evaluations.
Fichier non déposé
hal-00913250 , version 1 (03-12-2013)
  • HAL Id : hal-00913250 , version 1
Azadeh Khaleghi, Daniil Ryabko. Nonparametric multiple change point estimation in highly dependent time series. Proc. 24th International Conf. on Algorithmic Learning Theory (ALT'13), 2013, Singapore, Singapore. pp.382-396. ⟨hal-00913250⟩
72 Consultations
0 Téléchargements
