A confidence-set approach to signal denoising - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistical Methodology Année : 2013
The problem of filtering of finite-alphabet stationary ergodic time series is considered. A method for constructing a confidence set for the (unknown) signal is proposed, such that the resulting set has the following properties. First, it includes the unknown signal with probability , where is a parameter supplied to the filter. Second, the size of the confidence sets grows exponentially with a rate that is asymptotically equal to the conditional entropy of the signal given the data. Moreover, it is shown that this rate is optimal. We also show that the described construction of the confidence set can be applied to the case where the signal is corrupted by an erasure channel with unknown statistics.
hal-00913253 , version 1 (03-12-2013)
Boris Ryabko, Daniil Ryabko. A confidence-set approach to signal denoising. Statistical Methodology, 2013, 15, pp.115--120. ⟨10.1016/j.stamet.2013.05.003⟩. ⟨hal-00913253⟩
68 Consultations
0 Téléchargements
