From touch to string vibrations. I: Timing in the grand piano action, The Journal of the Acoustical Society of America, vol.88, issue.1, p.52, 1990. ,
DOI : 10.1121/1.399933
Observations on the transient components of the piano tone, 1993. ,
Physically Informed Signal Processing Methods for Piano Sound Synthesis: A Research Overview, EURASIP Journal on Advances in Signal Processing, vol.2003, issue.10, pp.941-952, 2003. ,
DOI : 10.1155/S1110865703304093
The simulation of piano string vibration: from physical models to finite difference schemes and digital waveguides Optimal shear correction factors in hierarchical plate modelling Conservative numerical methods for nonlinear strings Model for piano hammers: Experimental determination and digital simulation, Bou88] X Boutillon, pp.1095-11071, 1988. ,
Generation of longitudinal vibrations in piano strings: From physics to sound synthesis, The Journal of the Acoustical Society of America, vol.117, issue.4, pp.2268-2278, 2005. ,
DOI : 10.1121/1.1868212
Numerical simulations of piano strings. I. A physical model for a struck string using finite difference methods, Proceedings of the 10th French Acoustical Society Meeting, pp.1112-1118, 1994. ,
DOI : 10.1121/1.408459
Stability and dispersion analysis of improved time discretization for simply supported prestressed Timoshenko systems. Application to the stiff piano string, Wave Motion, vol.50, issue.3, pp.456-480, 2012. ,
DOI : 10.1016/j.wavemoti.2012.11.002
URL : https://hal.archives-ouvertes.fr/hal-00738233
Energy preserving schemes for nonlinear hamiltonian systems of wave equations. application to the vibrating piano string Design and tone in the mechanoacoustic piano. part ii. piano structure Piano strings and " phantom " partials, Con97] H A Conklin, pp.2779-2795695, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00534473
The Shear Coefficient in Timoshenko???s Beam Theory, Journal of Applied Mechanics, vol.33, issue.2, pp.335-340, 1966. ,
DOI : 10.1115/1.3625046
Modélisation du couplage corde -chevalet -table d'harmonie dans le registre aigu du piano, JJCAAS, pp.1-1, 2006. ,
Time-domain simulation of a guitar: Model and method, The Journal of the Acoustical Society of America, vol.114, issue.6, pp.3368-3383, 2003. ,
DOI : 10.1121/1.1629302
URL : https://hal.archives-ouvertes.fr/hal-00989042
La table d'harmonie du piano ? études modales en basses et moyennes fréquences Physical modeling of the piano, Thèse de Doctorat, pp.1-190926, 2004. ,
Dynamic modeling and experimental testing of a piano action mechanism with a flexible hammer shank, Journal of Computational and Nonlinear Dynamics, vol.3, pp.1-10, 1968. ,
Piano tone synthesis using digital filters by computer simulation Dispersion of waves in piano strings, Acoustics, Speech, and Signal Processing J Acoust Soc Am, vol.11, issue.831, pp.1293-1296305, 1986. ,
Time-domain modeling and numerical simulation of a kettledrum, The Journal of the Acoustical Society of America, vol.105, issue.6, pp.3545-3562, 1999. ,
DOI : 10.1121/1.424679
The effect of transverse shear deformation on the bending of elastic plates Hysteretic model of the grand piano hammer felt, Stu95] A Stulov, pp.69-772577, 1945. ,
Global classical solutions for quasilinear hyperbolic systems, 1994. ,
Modeling the dynamics of a compliant piano action mechanism impacting an elastic stiff string, Wei77] G Weinreich. Coupled piano strings, pp.4034-4042, 1977. ,
DOI : 10.1121/1.3125343
