Fundamentals of Aerodynamics, 1991. ,
Unsteady turbulent vortex structure downstream of a three dimensional cylinder, J. of Thermal Science and Technology, vol.29, issue.1, pp.91-98, 2009. ,
Is the dynamic procedure appropriate for all SGS model, European Conference on Computational Fluid Dynamics, pp.14-17, 2010. ,
A low-diffusion MUSCL scheme for LES on unstructured grids, Computers & Fluids, vol.33, issue.9, pp.1101-1129, 2004. ,
DOI : 10.1016/j.compfluid.2003.10.002
URL : https://hal.archives-ouvertes.fr/hal-00372840
Simulation of vortex shedding dominated flows past rigid and flexible structures, Computational Methods for Fluid-Structure Interaction, pp.1-30, 1999. ,
A dynamic variational multiscale method for large eddy simulations on unstructured meshes, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.13-16, pp.195-1667, 2006. ,
DOI : 10.1016/j.cma.2005.05.045
Variational Multiscale Large Eddy Simulation of Turbulent Flow in a Diffuser, Computational Mechanics, vol.550, issue.4, p.477495, 2012. ,
DOI : 10.1007/s00466-006-0044-y
A dynamic subgrid???scale eddy viscosity model, Physics of Fluids A: Fluid Dynamics, vol.3, issue.7, pp.1760-1765, 1991. ,
DOI : 10.1063/1.857955
A dynamic localization model for large-eddy simulation of turbulent flows, Journal of Fluid Mechanics, vol.256, issue.-1, pp.229-255, 1995. ,
DOI : 10.1063/1.861942
Large Eddy Simulation and the variational multiscale method, Computing and Visualization in Science, vol.3, issue.1-2, pp.47-59, 2000. ,
DOI : 10.1007/s007910050051
A variational multiscale method for the large eddy simulation of compressible turbulent flows on unstructured meshes??????application to vortex shedding, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.15-16, pp.1367-1383, 2004. ,
DOI : 10.1016/j.cma.2003.12.028
URL : https://hal.archives-ouvertes.fr/hal-00372839
Unstructured multigridding by volume agglomeration: Current status, Computers & Fluids, vol.21, issue.3, pp.397-433, 1992. ,
DOI : 10.1016/0045-7930(92)90047-Y
URL : https://hal.archives-ouvertes.fr/inria-00075334
A proposed modification of the Germano subgrid???scale closure method, Physics of Fluids A: Fluid Dynamics, vol.4, issue.3, pp.633-635, 1992. ,
DOI : 10.1063/1.858280
Flow Control of Circular Cylinders with Longitudinal Grooved Surfaces, AIAA Journal, vol.40, issue.10, pp.2027-2035, 2002. ,
DOI : 10.2514/2.1535
Extended lattice Boltzmann equation for simulation of flows around bluff bodies in high Reynolds number BBAA VI International Colloquium on Bluff Bodies Aerodynamics and Applications, 2008. ,
Effects of incidence and afterbody shape on flow past bluff cylinders, Journal of Wind Engineering and Industrial Aerodynamics, vol.53, issue.3, pp.375-399, 1994. ,
DOI : 10.1016/0167-6105(94)90092-2
The flapping shear layer formed by flow separation from the forward corner of a square cylinder, Journal of Fluid Mechanics, vol.173, issue.-1, pp.353-316, 1994. ,
DOI : 10.1007/BF00369117
A laser-Doppler velocimetry study of ensemble-averaged characteristics of the turbulent near wake of a square cylinder, Journal of Fluid Mechanics, vol.108, issue.-1, pp.285-319, 1995. ,
DOI : 10.1063/1.864048
A second order defect correction scheme for unsteady problems, Computers & Fluids, vol.25, issue.1, pp.9-27, 1996. ,
DOI : 10.1016/0045-7930(95)00027-5
URL : https://hal.archives-ouvertes.fr/inria-00074228
Status of Large Eddy Simulation: Results of a Workshop, Journal of Fluids Engineering, vol.119, issue.2, pp.248-262, 1997. ,
DOI : 10.1115/1.2819128
Subgrid-scale stress modelling based on the square of the velocity gradient tensor, Flow, Turbulence and Combustion, vol.62, issue.3, pp.183-200, 1999. ,
DOI : 10.1023/A:1009995426001
URL : https://hal.archives-ouvertes.fr/hal-00910373
Fluctuating lift on a circular cylinder: review and new measurements, Journal of Fluids and Structures, vol.17, issue.1, pp.57-96, 2003. ,
DOI : 10.1016/S0889-9746(02)00099-3
Variational multiscale large-eddy simulations of the flow past a circular cylinder: Reynolds number effects, Computers & Fluids, vol.47, issue.1, pp.44-50, 2011. ,
DOI : 10.1016/j.compfluid.2011.02.011
URL : https://hal.archives-ouvertes.fr/hal-00799280
Classical and variational multiscale LES of the flow around a circular cylinder on unstructured grids, Computers & Fluids, vol.39, issue.7, pp.1083-1094, 2010. ,
DOI : 10.1016/j.compfluid.2010.01.017
Approximate Riemann solvers, parameters, vectors and difference schemes Large-eddy simulations of the flow around a circular cylinder: effects of grid resolution and subgrid scale modeling, J. Comp. Phys Wind & Structures, vol.43, issue.66, pp.357-371419, 1981. ,
GENERAL CIRCULATION EXPERIMENTS WITH THE PRIMITIVE EQUATIONS, Monthly Weather Review, vol.91, issue.3, pp.99-164, 1963. ,
DOI : 10.1175/1520-0493(1963)091<0099:GCEWTP>2.3.CO;2
Towards the ultimate conservative scheme IV :A new approach to numerical convection, J. Comp. Phys, vol.23, pp.276-299, 1977. ,
Direct numerical simulation of turbulence at lower costs, Journal of Engineering Mathematics, vol.32, p.143159, 1997. ,
