Combining graph laplacians for semi-supervised learning, Proceedings of the 19th conference Annual Conference on Neural Information Processing Systems (NIPS-05), pp.67-74, 2006. ,
Hypergraphs: combinatorics of finite sets. North-Holland Mathematical Library, 1989. ,
Riemannian Metric and Geometric Mean for Positive Semidefinite Matrices of Fixed Rank, SIAM Journal on Matrix Analysis and Applications, vol.31, issue.3, pp.1055-1070, 2009. ,
DOI : 10.1137/080731347
Interpretations of negative probabilities. arXiv preprint arXiv:1008.1287, 2010. ,
Flows on hypergraphs, Mathematical Programming, pp.195-217, 1997. ,
DOI : 10.1007/BF02614371
The electrical resistance of a graph captures its commute and cover times, Computational Complexity, 1996. ,
Random-walk computation of similarities between nodes of a graph with application to collaborative recommendation. Knowledge and Data Engineering, IEEE Transactions on, vol.19, issue.3, pp.355-369, 2007. ,
Directed hypergraphs and applications, Discrete Applied Mathematics, vol.42, issue.2-3, pp.177-201, 1993. ,
DOI : 10.1016/0166-218X(93)90045-P
URL : http://doi.org/10.1016/0166-218x(93)90045-p
Max Horn SAT and the minimum cut problem in directed hypergraphs, Mathematical Programming, pp.213-237, 1998. ,
DOI : 10.1007/BF01581727
A graph-based framework for multi-task multi-view learning, Proceedings of the 28th International Conference on Machine Learning (ICML-11), pp.25-32, 2011. ,
Online learning over graphs, Proceedings of the 22nd international conference on Machine learning , ICML '05, pp.305-312, 2005. ,
DOI : 10.1145/1102351.1102390
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.95.5320
Bounds for the least laplacian eigenvalue of a signed graph, Acta Mathematica Sinica, vol.21, issue.4, pp.955-960, 2005. ,
Resistance distance, Journal of Mathematical Chemistry, vol.12, issue.1, pp.81-95, 1993. ,
Spectral Analysis of Signed Graphs for Clustering, Prediction and Visualization, Proceedings of the 10th SIAM International Conference on Data Mining (SDM-10), pp.559-559, 2010. ,
DOI : 10.1137/1.9781611972801.49
The principal components analysis of a graph, and its relationshipsto spectral clustering, Proceedings of the 15th European Conference on Machine Learning, pp.371-383, 2004. ,
Weisfeiler-lehman graph kernels, Journal of Machine Learning Research, vol.12, pp.2539-2561, 2011. ,
A co-regularization approach to semi-supervised learning with multiple views, Proceedings of ICML Workshop on Learning with Multiple Views, pp.74-79, 2005. ,
A multi-kernel framework for inductive semi-supervised learning, Proceedings of the 18th European Symposium on Artificial Neural Networks, Computational Intelligence and Machine Learning, pp.27-29, 2011. ,
Fast protein classification with multiple networks, Bioinformatics, vol.21, issue.Suppl 2, pp.59-65, 2005. ,
DOI : 10.1093/bioinformatics/bti1110
A tutorial on spectral clustering, Statistics and computing, vol.17, issue.4, pp.395-416, 2007. ,
A new analysis of co-training, Proceedings of the 27th International Conference on Machine Learning (ICML-10), pp.1135-1142, 2010. ,
Simple and efficient multiple kernel learning by group lasso, Proceedings of the 27th International Conference on Machine Learning (ICML-10), pp.1175-1182, 2010. ,
Spectral clustering and transductive learning with multiple views, Proceedings of the 24th international conference on Machine learning, ICML '07, pp.1159-1166, 2007. ,
DOI : 10.1145/1273496.1273642
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.80.93
Learning from labeled and unlabeled data on a directed graph, Proceedings of the 22nd international conference on Machine learning , ICML '05, pp.1036-1043, 2005. ,
DOI : 10.1145/1102351.1102482
Learning with hypergraphs: Clustering, classification, and embedding, Proceedings of the 20th conference Annual Conference on Neural Information Processing Systems (NIPS-06), pp.1601-1608, 2007. ,
