On the Choice of Wavespeeds for the HLLC Riemann Solver, SIAM Journal on Scientific Computing, vol.18, issue.6, pp.1553-1570, 1997. ,
DOI : 10.1137/S1064827593260140
Optimal control of the cylinder wake in the laminar regime by trust-region methods and POD reduced-order models, Journal of Computational Physics, vol.227, issue.16, p.227, 2008. ,
DOI : 10.1016/j.jcp.2008.04.034
URL : https://hal.archives-ouvertes.fr/hal-00368500
Optimization of active flow control of a naca 0012 airfoil by using a continuous adjoint approach, European Congress on Computational Methods in Applied Sciences and Engineering, 2012. ,
Contrôle des décollements par jet synthétique, 2007. ,
Unsteady Simulation of Synthetic Jet in a Crossflow, AIAA Journal, vol.44, issue.2, 2006. ,
DOI : 10.2514/1.13462
Compressible flow solvers using unstructured grids, INRIA Research Report, vol.1732, 1992. ,
URL : https://hal.archives-ouvertes.fr/inria-00076971
Active flow control applied to an airfoil, 36th AIAA Aerospace Sciences Meeting and Exhibit, pp.98-0210, 1998. ,
DOI : 10.2514/6.1998-210
Optimal Location of a Synthetic Jet on an Airfoil for Stall Control, Journal of Fluids Engineering, vol.129, issue.7, pp.825-833, 2007. ,
DOI : 10.1115/1.2742729
Optimization of a synthetic jet actuator for aerodynamic stall control. Computers and Fluids, pp.624-638, 2006. ,
Efficiency improvements of RANS-based analysis and optimization using implicit and adjoint methods on unstructured grids, 2006. ,
Active Flow Control of Wing Separated Flow, Volume 1: Fora, Parts A, B, C, and D, 2003. ,
DOI : 10.1115/FEDSM2003-45237
Characterization of a compact, high power synthetic jet actuator for flow separation control, AIAA Paper, pp.2002-0127, 2002. ,
Active Control and Drag Optimization for Flow Past a Circular Cylinder, Journal of Computational Physics, vol.163, issue.1, pp.83-117, 2000. ,
DOI : 10.1006/jcph.2000.6556
Low-cost implicit schemes for all-speed flows on unstructured meshes, International Journal for Numerical Methods in Fluids, vol.42, issue.5, pp.493-526, 2008. ,
DOI : 10.1002/fld.1730
URL : https://hal.archives-ouvertes.fr/hal-00357646
Numerical simulation of synthetic jet actuators, 4th Shear Flow Control Conference, 1997. ,
DOI : 10.2514/6.1997-1824
Two-equation eddy-viscosity turbulence models for engineering applications, AIAA Journal, vol.32, issue.8, 1994. ,
DOI : 10.2514/3.12149
Delay of airfoil stall by periodic excitation, Journal of Aircraft, vol.33, issue.4, pp.691-707, 1996. ,
DOI : 10.2514/3.47003
Vectoring and small-scale motions effected in free shear flows using synthetic jet actuators, 35th Aerospace Sciences Meeting and Exhibit, 1997. ,
DOI : 10.2514/6.1997-213
Optimal location fo suction or blowing jets using the continuous adjoint approach, European Congress on Computational Methods in Applied Sciences and Engineering ECCOMAS 2010 Lisbon, 2010. ,
