A robust and efficient valve model based on resistive immersed surfaces, International Journal for Numerical Methods in Biomedical Engineering, vol.539, issue.6, pp.937-959, 2012. ,
DOI : 10.1002/cnm.2474
URL : https://hal.archives-ouvertes.fr/hal-00717213
A finite element method for domain decomposition with non-matching grids, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.2, pp.209-225, 2003. ,
DOI : 10.1051/m2an:2003023
URL : https://hal.archives-ouvertes.fr/inria-00073065
Les équations des stokes et de Navier- Stokes avec des conditions limites sur la pression (on Stokes and Navier-stokes equations with boundary condition on the pressure) Non-linear partial differential equations and their applications, Pitman Res. Notes Math. Ser, vol.181, pp.1985-86179, 1988. ,
Fractional-Step Schemes for the Coupling of Distributed and Lumped Models in Hemodynamics, SIAM Journal on Scientific Computing, vol.35, issue.3, pp.551-575, 2013. ,
DOI : 10.1137/120874412
URL : https://hal.archives-ouvertes.fr/hal-00690493
On the continuity of mean total normal stress in geometrical multiscale cardiovascular problems, Journal of Computational Physics, vol.251, pp.136-155, 2013. ,
DOI : 10.1016/j.jcp.2013.05.037
A unified variational approach for coupling 3D???1D models and its blood flow applications, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.41-44, pp.4391-4410, 2007. ,
DOI : 10.1016/j.cma.2007.05.008
Operator-splitting and Lagrange multiplier domain decomposition methods for numerical simulation of two coupled Navier-Stokes fluids, Int. J. Appl. Math. Comput. Sci, vol.16, pp.419-429, 2006. ,
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.766-784, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
An unfitted Nitsche method for incompressible fluidstructure interaction using overlapping meshes ,
URL : https://hal.archives-ouvertes.fr/hal-00918272
Explicit strategies for incompressible fluid-structure interaction problems: Nitsche type mortaring versus Robin-Robin coupling, International Journal for Numerical Methods in Engineering, vol.13, issue.1, pp.739-758, 2014. ,
DOI : 10.1002/nme.4607
URL : https://hal.archives-ouvertes.fr/hal-00819948
A unified stabilized method for Stokes??? and Darcy's equations, Journal of Computational and Applied Mathematics, vol.198, issue.1, pp.35-51, 2007. ,
DOI : 10.1016/j.cam.2005.11.022
A Domain Decomposition Method Based on Weighted Interior Penalties for Advection???Diffusion???Reaction Problems, SIAM Journal on Numerical Analysis, vol.44, issue.4, pp.1612-1638, 2006. ,
DOI : 10.1137/050634736
Partitioned Time Stepping for a Parabolic Two Domain Problem, SIAM Journal on Numerical Analysis, vol.47, issue.5, pp.3526-3549, 2009. ,
DOI : 10.1137/080740891
Decoupled Time Stepping Methods for Fluid-Fluid Interaction, SIAM Journal on Numerical Analysis, vol.50, issue.3, pp.1297-1319, 2012. ,
DOI : 10.1137/090773362
A partitioned fluid???structure algorithm for elastic thin valves with contact, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201750, 2008. ,
DOI : 10.1016/j.cma.2007.03.019
URL : https://hal.archives-ouvertes.fr/hal-00701780
On the coupling of 3D and 1D Navier???Stokes equations for flow problems in compliant vessels, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.6-7, pp.561-582, 2001. ,
DOI : 10.1016/S0045-7825(01)00302-4
URL : https://hal.archives-ouvertes.fr/hal-00691928
On the stability of the coupling of 3D and 1D fluidstructure interaction models for blood flow simulations, ESAIM: Mathematical Modelling and Numerical Analysis, issue.04, pp.41743-769, 2007. ,
A scalable domain decomposition method for ultraparallel arterial flow simulations, Communications in Computational Physics, vol.4, issue.5, pp.1151-1169, 2008. ,
A finite element method on composite grids based on Nitsche's method, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.3, pp.495-514, 2003. ,
DOI : 10.1051/m2an:2003039
Nitsche's method for interface problems in computa-tional mechanics, GAMM-Mitteilungen, vol.15, issue.2, pp.183-206, 2005. ,
DOI : 10.1002/gamm.201490018
Nitsche's method for coupling non-matching meshes in fluid-structure vibration problems, Computational Mechanics, vol.32, issue.1-2, pp.134-139, 2003. ,
DOI : 10.1007/s00466-003-0467-7
Nitsche's method combined with space???time finite elements for ALE fluid???structure interaction problems, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.39-41, pp.4195-4206, 2004. ,
DOI : 10.1016/j.cma.2003.09.029
New development in freefem++, Journal of Numerical Mathematics, vol.20, issue.3-4, pp.251-265, 2012. ,
DOI : 10.1515/jnum-2012-0013
ARTIFICIAL BOUNDARIES AND FLUX AND PRESSURE CONDITIONS FOR THE INCOMPRESSIBLE NAVIER-STOKES EQUATIONS, International Journal for Numerical Methods in Fluids, vol.8, issue.5, pp.325-352, 1996. ,
DOI : 10.1002/(SICI)1097-0363(19960315)22:5<325::AID-FLD307>3.0.CO;2-Y
On the accuracy of the rotation form in simulations of the Navier???Stokes equations, Journal of Computational Physics, vol.228, issue.9, pp.3433-3447, 2009. ,
DOI : 10.1016/j.jcp.2009.01.027
Algorithms for the partitioned solution of weakly coupled fluid models for cardiovascular flows, International Journal for Numerical Methods in Biomedical Engineering, vol.18, issue.1-2, pp.2035-2057, 2011. ,
DOI : 10.1002/cnm.1457
A stabilized Nitsche overlapping mesh method for the Stokes problem, Numerische Mathematik, vol.50, issue.1, 2014. ,
DOI : 10.1007/s00211-013-0603-z
External tissue support and fluid???structure simulation in blood flows, Biomechanics and Modeling in Mechanobiology, vol.31, issue.3, pp.1-18, 2012. ,
DOI : 10.1007/s10237-011-0289-z
URL : https://hal.archives-ouvertes.fr/hal-00701801
??ber ein Variationsprinzip zur L??sung von Dirichlet-Problemen bei Verwendung von Teilr??umen, die keinen Randbedingungen unterworfen sind, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.12, issue.1, pp.9-15, 1971. ,
DOI : 10.1007/BF02995904
The equation of oceanic motion, 1979. ,
Numerical treatment of boundary conditions to replace lateral branches in hemodynamics, International Journal for Numerical Methods in Biomedical Engineering, vol.30, issue.4, pp.1165-1183, 2012. ,
DOI : 10.1002/cnm.2488
Analysis of a Geometrical Multiscale Model Based on the Coupling of ODE and PDE for Blood Flow Simulations, Multiscale Modeling & Simulation, vol.1, issue.2, pp.173-195, 2003. ,
DOI : 10.1137/S1540345902408482
Navier-Stokes Equations, Studies in Mathematics and its Applications, 1979. ,
DOI : 10.1090/chel/343
Galerkin Finite Element Methods for Parabolic Problems, Series in Computational Mathematics, 2006. ,
DOI : 10.1007/978-3-662-03359-3
Flow rate defective boundary conditions in haemodynamics simulations, International Journal for Numerical Methods in Fluids, vol.191, issue.8-9, pp.803-816, 2005. ,
DOI : 10.1002/fld.843
18 5.2.1 Static pressure formulations, p.24 ,
