Generalized Subdifferentials of the Sign Change Counting Function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
The counting function on binary values is extended to the signed case in order to count the number of transitions between contiguous locations. A generalized subdifferential for the sign change counting function is given where classical subdifferentials remain intractable. An attempt to prove global optimality at some point, for the 4-dimensional first non trivial example, is made by using a sufficient condition specially tailored among all the cases for this subdifferential.
hal-00915606 , version 1 (09-12-2013)
Dominique Fortin, Ider Tseveendorj. Generalized Subdifferentials of the Sign Change Counting Function. 2013. ⟨hal-00915606⟩
237 Consultations
0 Téléchargements
