Wildcarded Identity-Based Encryption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptology Année : 2011
In this paper, we introduce a new primitive called identity-based encryption with wildcards, or WIBE for short. It allows a sender to encrypt messages to a whole range of receivers whose identities match a certain pattern. This pattern is defined through a sequence of fixed strings and wildcards, where any string can take the place of a wildcard in a matching identity. Our primitive can be applied to provide an intuitive way to send encrypted email to groups of users in a corporate hierarchy. We propose a full security notion and give efficient implementations meeting this notion under different pairing-related assumptions, both in the random oracle model and in the standard model.
hal-00915848 , version 1 (09-12-2013)
Michel Abdalla, James Birkett, Dario Catalano, Alexander W. Dent, John Malone-Lee, et al.. Wildcarded Identity-Based Encryption. Journal of Cryptology, 2011, 24 (1), pp.42-82. ⟨10.1007/s00145-010-9060-3⟩. ⟨hal-00915848⟩
124 Consultations
0 Téléchargements
