New interface
Conference papers
Numerical approach to a problem of hydroelectric resources management
Abstract : In this paper we consider a simplified model for a system of hydro-electric power stations with reversible turbines. The objective of our work is to obtain the optimal profit of power production satisfying restrictions on the water level in the reservoirs. Two different numerical approaches are applied and compared. These approaches center on global optimization techniques (Chen-Burer algorithm) and on Projection Estimation Refinement method (PER method) used to reduce the dimension of the problem.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00916846
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Tuesday, December 10, 2013 - 6:01:11 PM
Last modification on : Tuesday, May 3, 2022 - 5:52:02 PM
Links full text
Identifiers
Collections
Citation
V. A. Bushenkov, Margarida Ferreira, Ana Filipa Ribeiro, G. V. Smirnov. Numerical approach to a problem of hydroelectric resources management. 11th International Conference on Numerical Analysis and Applied Mathematics (ICNAAM 2013), 2013, Rhodes, Greece. pp.630-633, ⟨10.1063/1.4825570⟩. ⟨hal-00916846⟩
Share
Metrics
Record views
115
