New interface
Other publications
3D-CE5.h: Additional merge candidates derived from shifted disparity candidate predictors
Laurent Guillo 1 Christine Guillemot 1
1 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : The coding performance of the HTM 5.0.1 can be improved by inserting in the candidate merge list two new candidates, the maximal length of list still being equal to 6. These candidates are derived from the first disparity compensated candidate found in the list, which is then horizontally shifted by +4 and -4. Bit rate gains are respectively 0.4% and 0.5% for the side views 1 and 2. The overall bit rate gain is 0.2%.
Complete list of metadata
Cited literature [4 references]  Display  Hide  Download
https://hal.inria.fr/hal-00917123
Contributor : Laurent Guillo Connect in order to contact the contributor
Submitted on : Wednesday, December 11, 2013 - 1:20:26 PM
Last modification on : Thursday, January 20, 2022 - 5:33:18 PM
Long-term archiving on: : Friday, March 14, 2014 - 10:41:05 AM
JCT3V-C0148.pdf
Identifiers
  • HAL Id : hal-00917123, version 1
Citation
Laurent Guillo, Christine Guillemot. 3D-CE5.h: Additional merge candidates derived from shifted disparity candidate predictors. 2013. ⟨hal-00917123⟩
Share
Metrics
Record views
418
Files downloads
177
