New interface
Conference papers
Optimal control of dynamical systems governed by partial differential equations: A perspective from real-life applications
Abstract : This survey article summarizes some ideas of the two principle procedures for solving optimal control problems governed by partial differential (algebraic) equations: the indirect method or first-optimize-then-discretize approach based on first-order necessary conditions, and the direct method or first-discretize-then-optimize approach based on non-linear programming software. The focus of this paper is to discuss some pros and cons when applications come from real-life problems. It also glances at the main method which currently may have the best chance for online applications in PDE constrained optimization. The demonstrator example deals with the optimal control of a certain type of high temperature fuel cell system.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00917300
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Wednesday, December 11, 2013 - 4:10:51 PM
Last modification on : Monday, March 21, 2016 - 11:34:34 AM
Identifiers
Collections
Citation
Hans-Josef Pesch. Optimal control of dynamical systems governed by partial differential equations: A perspective from real-life applications. 77th Vienna International Conference on Mathematical Modelling, 2012, Vienna, Austria. pp.1-12, ⟨10.3182/20120215-3-AT-3016.00003⟩. ⟨hal-00917300⟩
Share
Metrics
Record views
79
