Some examples of high order simulations parallel of inviscid flows on unstructured and hybrid meshes by residual distribution schemes, Computers & Fluids, vol.61, pp.1-13, 2012. ,
DOI : 10.1016/j.compfluid.2011.05.014
URL : https://hal.archives-ouvertes.fr/hal-00652390
Construction of very high order residual distribution schemes for steady inviscid flow problems on hybrid unstructured meshes, Journal of Computational Physics, vol.230, issue.11, pp.4103-4136, 2011. ,
DOI : 10.1016/j.jcp.2010.07.035
URL : https://hal.archives-ouvertes.fr/hal-00652412
High-order fluctuation schemes on triangular meshes, Journal of Scientific Computing, vol.19, issue.1/3, pp.3-36, 2003. ,
DOI : 10.1023/A:1025335421202
On the flexibility of agglomeration based physical space discontinuous Galerkin discretizations, Journal of Computational Physics, vol.231, issue.1, pp.45-65, 2012. ,
DOI : 10.1016/j.jcp.2011.08.018
URL : https://hal.archives-ouvertes.fr/hal-00562219
Discontinuous Galerkin solution of the Reynolds-averaged Navier-Stokes and k ? ? turbulence model equations. Computers & Fluids, MAY-JUN 2005. Workshop on Residual Distribution Schemes, Discontinuous Galerkin Schemes, Multidimensional Schemes and Mesh Adaptation, pp.4-5507, 2002. ,
A High-Order Accurate Discontinuous Finite Element Method for the Numerical Solution of the Compressible Navier???Stokes Equations, Journal of Computational Physics, vol.131, issue.2, pp.267-279, 1997. ,
DOI : 10.1006/jcph.1996.5572
Parallel, adaptive finite element methods for conservation laws, Applied Numerical Mathematics, vol.14, issue.1-3, pp.255-283, 1994. ,
DOI : 10.1016/0168-9274(94)90029-9
Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.32, issue.1-3, pp.199-25981, 1981. ,
DOI : 10.1016/0045-7825(82)90071-8
The local projection $P^0-P^1$-discontinuous-Galerkin finite element method for scalar conservation laws, ESAIM: Mathematical Modelling and Numerical Analysis, vol.23, issue.4, pp.565-592, 1989. ,
DOI : 10.1051/m2an/1989230405651
Runge-Kutta discontinuous Galerkin methods for convection-dominated problems, Journal of Scientific Computing, vol.16, issue.3, pp.173-261, 2001. ,
DOI : 10.1023/A:1012873910884
An encyclopaedia of cubature formulas, Journal of Complexity, vol.19, issue.3, pp.445-453, 2001. ,
DOI : 10.1016/S0885-064X(03)00011-6
Residual Distribution Schemes: Foundations and Analysis, Encyclopedia of Computational Mechanics, 2007. ,
DOI : 10.1002/0470091355.ecm054
URL : https://hal.archives-ouvertes.fr/hal-00402592
Spectral methods on triangles and other domains, Journal of Scientific Computing, vol.1, issue.1, pp.345-390, 1991. ,
DOI : 10.1007/BF01060030
Some results on uniformly high-order accurate essentially nonoscillatory schemes, Applied Numerical Mathematics, vol.2, issue.3-5, pp.3-5347, 1986. ,
DOI : 10.1016/0168-9274(86)90039-5
On a cell entropy inequality for discontinuous Galerkin methods, Math. Comp, vol.62, issue.206, pp.531-538, 1994. ,
ADIGMA -A European Initiative on the Development of Adaptive Higher-Order Variational Methods for Aerospace Applications, Harmen van der Ven, and Kaare Sørensen of Notes on Numerical Fluid Mechanics and Multidisciplinary Design, 2010. ,
DOI : 10.1007/978-3-642-03707-8
An Adaptive Discontinuous Galerkin Technique with an Orthogonal Basis Applied to Compressible Flow Problems, SIAM Review, vol.45, issue.1, pp.53-72, 2003. ,
DOI : 10.1137/S00361445023830
Fluctuations and signals -a framework for numerical evolution problems, Numerical Methods for Fluids Dynamics, pp.219-257, 1982. ,
Efficient implementation of essentially non-oscillatory shock-capturing schemes, Journal of Computational Physics, vol.77, issue.2, pp.439-471, 1988. ,
DOI : 10.1016/0021-9991(88)90177-5
Higher-order finite element methods, With 1 CD-ROM (Windows, Macintosh, UNIX and LINUX), 2004. ,
A New Class of Optimal High-Order Strong-Stability-Preserving Time Discretization Methods, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.469-491, 2002. ,
DOI : 10.1137/S0036142901389025
Approximate calculation of multiple integrals, N.J, 1971. ,
Low-Dissipative High-Order Shock-Capturing Methods Using Characteristic-Based Filters, Journal of Computational Physics, vol.150, issue.1, pp.199-238, 1999. ,
DOI : 10.1006/jcph.1998.6177
A set of symmetric quadrature rules on triangles and tetrahedra, Journal of Computational Mathematics, vol.27, issue.1, pp.89-96, 2009. ,
