New interface
Conference papers
Lambda-Upsilon-Omega: An Assistant Algorithms Analyzer
Philippe Flajolet B. Salvy P. Zimmermann 1
1 ALGO - Algorithms
Inria Paris-Rocquencourt
Abstract : Lambda-Upsilon-Omega, ΛΥΩ, is a system designed to perform automatic analysis of well-defined classes of algorithms operating over "decomposable" data structures. It consists of an 'Algebraic Analyzer' System that compiles algorithms specifications into generating functions of average costs, and an 'Analytic Analyzer' System that extracts asymptotic informations on coefficients of generating functions. The algebraic part relies on recent methodologies in combinatorial analysis based on systematic correspondences between structural type definitions and counting generating functions. The analytic part makes use of partly classical and partly new correspondences between singularities of analytic functions and the growth of their Taylor coefficients. The current version ΛΥΩ0 of ΛΥΩ implements as basic data types, term trees as encountered in symbolic algebra systems. The analytic analyzer can treat large classes of functions with explicit expressions. In this way, ΛΥΩ0 can generate in the current stage about a dozen non-trivial average case analyses of algorithms like: formal differentiation, some algebraic simplification and matching algorithms. Its analytic analyzer can determine asymptotic expansions for large classes of generating functions arising in the analysis of algorithms. The outline of a design for a full system is also discussed here. The long term goal is to include a fairly rich set of data structuring mechanisms including some general recursive type definitions, and have the analytic analyzer treat wide classes of functional equations as may be encountered in combinatorial analysis and the analysis of algorithms.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00917731
Contributor : Paul Zimmermann Connect in order to contact the contributor
Submitted on : Thursday, December 12, 2013 - 12:42:22 PM
Last modification on : Thursday, February 3, 2022 - 11:18:36 AM
Links full text
Identifiers
Collections
Citation
Philippe Flajolet, B. Salvy, P. Zimmermann. Lambda-Upsilon-Omega: An Assistant Algorithms Analyzer. Applied Algebra, Algebraic Algorithms and Error-Correcting Codes, 1989, Rome, Italy. pp.201-212, ⟨10.1007/3-540-51083-4_60⟩. ⟨hal-00917731⟩
Share
Metrics
Record views
80
