A fictitious domain/mortar element method for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.79, issue.7, pp.743-761, 2001. ,
DOI : 10.1002/1097-0363(20010415)35:7<743::AID-FLD109>3.0.CO;2-A
A Nitsche extended finite element method for incompressible elasticity with discontinuous modulus of elasticity, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.41-44, pp.41-443352, 2009. ,
DOI : 10.1016/j.cma.2009.06.017
URL : https://hal.archives-ouvertes.fr/inria-00341737
On the hyper-elastic formulation of the immersed boundary method, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.25-28, pp.25-282210, 2008. ,
DOI : 10.1016/j.cma.2007.09.015
On the Stabilization of Finite Element Approximations of the Stokes Equations, Efficient solutions of elliptic systems, pp.11-19, 1984. ,
DOI : 10.1007/978-3-663-14169-3_2
Ghost penalty, Comptes Rendus Mathematique, vol.348, issue.21-22, pp.21-221217, 2010. ,
DOI : 10.1016/j.crma.2010.10.006
URL : https://hal.archives-ouvertes.fr/inria-00543248
CutFEM: Discretizing geometry and partial differential equations, International Journal for Numerical Methods in Engineering, vol.128, issue.1, 2014. ,
DOI : 10.1002/nme.4823
URL : http://urn.kb.se/resolve?urn=urn:nbn:se:umu:diva-110976
Fictitious domain finite element methods using cut elements: II. A stabilized Nitsche method, Applied Numerical Mathematics, vol.62, issue.4, pp.328-341, 2012. ,
DOI : 10.1016/j.apnum.2011.01.008
Fictitious domain methods using cut elements: III. A stabilized Nitsche method for Stokes??? problem, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.3, p.2013 ,
DOI : 10.1051/m2an/2013123
A partitioned fluid???structure algorithm for elastic thin valves with contact, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201750, 2008. ,
DOI : 10.1016/j.cma.2007.03.019
URL : https://hal.archives-ouvertes.fr/hal-00701780
Analysis of a linear fluid-structure interaction problem, Discrete Contin. Dyn. Syst, vol.9, issue.3, pp.633-650, 2003. ,
Theory and practice of finite elements, Applied Mathematical Sciences, vol.159, 2004. ,
DOI : 10.1007/978-1-4757-4355-5
Coupling schemes for incompressible fluid-structure interaction: implicit, semi-implicit and explicit, Cardiovascular Mathematics. Modeling and simulation of the circulatory system of Modeling, Simulation and Applications, pp.59-108, 2009. ,
DOI : 10.1007/BF03322593
An eXtended Finite Element Method/Lagrange multiplier based approach for fluid???structure interaction, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201699, 2008. ,
DOI : 10.1016/j.cma.2007.07.002
A distributed Lagrange multiplier/fictitious domain method for particulate flows, International Journal of Multiphase Flow, vol.25, issue.5, pp.755-794, 1999. ,
DOI : 10.1016/S0301-9322(98)00048-2
An unfitted finite element method, based on Nitsche???s method, for elliptic interface problems, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.47-48, pp.47-485537, 2002. ,
DOI : 10.1016/S0045-7825(02)00524-8
URL : https://hal.archives-ouvertes.fr/hal-01352903
A finite element method for the simulation of strong and weak discontinuities in solid mechanics, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.33-35, pp.33-353523, 2004. ,
DOI : 10.1016/j.cma.2003.12.041
A finite element method on composite grids based on Nitsche's method, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.3, pp.495-514, 2003. ,
DOI : 10.1051/m2an:2003039
Nitsche's method for interface problems in computa-tional mechanics, GAMM-Mitteilungen, vol.15, issue.2, pp.183-206, 2005. ,
DOI : 10.1002/gamm.201490018
Nitsche's method combined with space???time finite elements for ALE fluid???structure interaction problems, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.39-41, pp.39-414195, 2004. ,
DOI : 10.1016/j.cma.2003.09.029
New development in freefem++, Journal of Numerical Mathematics, vol.20, issue.3-4, pp.251-265, 2012. ,
DOI : 10.1515/jnum-2012-0013
Numerical analysis of a linearised fluid-structure interaction problem, Numer. Math, vol.87, issue.2, pp.317-354, 2000. ,
An Eulerian???Lagrangian method for fluid???structure interaction based on level sets, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.17-18, pp.17-182070, 2006. ,
DOI : 10.1016/j.cma.2005.02.025
A stabilized Nitsche overlapping mesh method for the Stokes problem, Numerische Mathematik, vol.50, issue.1, pp.1-29, 2014. ,
DOI : 10.1007/s00211-013-0603-z
Efficient Implementation of Finite Element Methods on Nonmatching and Overlapping Meshes in Three Dimensions, SIAM Journal on Scientific Computing, vol.35, issue.1, pp.23-47, 2013. ,
DOI : 10.1137/11085949X
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
A new face-oriented stabilized XFEM approach for 2D and 3D incompressible Navier???Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.276, 2014. ,
DOI : 10.1016/j.cma.2014.02.014
