Robin based semi-implicit coupling in fluidstructure interaction: Stability analysis and numerics, SIAM J. Sci. Comput, issue.6, pp.314041-4065, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00361284
Convergence analysis of a projection semi-implicit coupling scheme for fluid???structure interaction problems, Numerische Mathematik, vol.96, issue.1, pp.721-767, 2010. ,
DOI : 10.1007/s00211-010-0311-x
URL : https://hal.archives-ouvertes.fr/hal-00860416
Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, pp.7027-7051, 2008. ,
DOI : 10.1016/j.jcp.2008.04.006
Modular vs. non-modular preconditioners for fluid???structure systems with large added-mass effect, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.49-50, pp.49-504216, 2008. ,
DOI : 10.1016/j.cma.2008.04.018
Splitting Methods Based on Algebraic Factorization for Fluid-Structure Interaction, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1778-1805, 2008. ,
DOI : 10.1137/070680497
Sub-iteration leads to accuracy and stability enhancements of semi-implicit schemes for the Navier???Stokes equations, Journal of Computational Physics, vol.230, issue.12, pp.4384-4402, 2011. ,
DOI : 10.1016/j.jcp.2011.01.011
A convergence study of a new partitioned fluid???structure interaction algorithm based on fictitious mass and damping, Journal of Computational Physics, vol.231, issue.2, pp.629-652, 2012. ,
DOI : 10.1016/j.jcp.2011.09.025
PETSc users manual, 2014. ,
Efficient Management of Parallelism in Object-Oriented Numerical Software Libraries, Modern Software Tools in Scientific Computing, pp.163-202, 1997. ,
DOI : 10.1007/978-1-4612-1986-6_8
An analysis of a new stable partitioned algorithm for FSI problems. Part II: Incompressible flow and structural shells, Journal of Computational Physics, vol.268, pp.399-416, 2014. ,
DOI : 10.1016/j.jcp.2014.03.004
Models and Finite Elements for Thin-Walled Structures, chapter 3, 2004. ,
On the physical significance of higher order kinematic and static variables in a three-dimensional shell formulation, International Journal of Solids and Structures, vol.37, issue.46-47, pp.6933-6960, 2000. ,
DOI : 10.1016/S0020-7683(99)00321-2
On the Stabilization of Finite Element Approximations of the Stokes Equations, Efficient solutions of elliptic systems, pp.11-19, 1984. ,
DOI : 10.1007/978-3-663-14169-3_2
Accurate Projection Methods for the Incompressible Navier???Stokes Equations, Journal of Computational Physics, vol.168, issue.2, pp.464-499515, 2001. ,
DOI : 10.1006/jcph.2001.6715
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8766, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
Explicit strategies for incompressible fluid-structure interaction problems: Nitsche type mortaring versus Robin-Robin coupling, International Journal for Numerical Methods in Engineering, vol.13, issue.1, 2013. ,
DOI : 10.1002/nme.4607
URL : https://hal.archives-ouvertes.fr/hal-00819948
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/hal-00695954
The Finite Element Analysis of Shells -Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
MODELING OF THE INCLUSION OF A REINFORCING SHEET WITHIN A 3D MEDIUM, Mathematical Models and Methods in Applied Sciences, vol.13, issue.04, pp.573-595, 2003. ,
DOI : 10.1142/S0218202503002635
URL : https://hal.archives-ouvertes.fr/hal-00839241
Numerical solution of the Navier-Stokes equations, Mathematics of Computation, vol.22, issue.104, pp.745-762, 1968. ,
DOI : 10.1090/S0025-5718-1968-0242392-2
Parallel Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, SIAM Journal on Scientific Computing, vol.33, issue.4, pp.1598-1622, 2011. ,
DOI : 10.1137/090772836
Partitioned Simulation of Fluid-Structure Interaction, Archives of Computational Methods in Engineering, vol.196, issue.8, pp.185-238, 2013. ,
DOI : 10.1007/s11831-013-9085-5
Stability of a coupling technique for partitioned solvers in FSI applications, Computers & Structures, vol.86, issue.23-24, pp.23-242224, 2008. ,
DOI : 10.1016/j.compstruc.2008.05.005
An arbitrary lagrangian-eulerian finite element method for transient dynamic fluid-structure interactions, Computer Methods in Applied Mechanics and Engineering, vol.33, issue.1-3, pp.689-723, 1982. ,
DOI : 10.1016/0045-7825(82)90128-1
Effect of baffles on a partially filled cubic tank: Numerical simulation and experimental validation, Computers & Structures, vol.87, issue.3-4, pp.3-4198, 2009. ,
DOI : 10.1016/j.compstruc.2008.10.008
Coupling schemes for incompressible fluid-structure interaction: implicit, semi-implicit and explicit, SeMA Journal, vol.40, issue.12, pp.59-108, 2011. ,
DOI : 10.1007/BF03322593
Incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible fluid, Comptes Rendus Mathematique, vol.349, issue.7-8, pp.473-477, 2011. ,
DOI : 10.1016/j.crma.2011.03.001
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1007/s00211-012-0481-9
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
A fully decoupled scheme for the interaction of a thin-walled structure with an incompressible fluid, Comptes Rendus Mathematique, vol.351, issue.3-4, pp.351-354, 2013. ,
DOI : 10.1016/j.crma.2013.02.015
A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.021
Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction: Stability analysis and numerics, International Journal for Numerical Methods in Engineering, vol.38, issue.6-7, 2014. ,
DOI : 10.1002/nme.4785
Explicit Robin???Neumann schemes for the coupling of incompressible fluids with thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.566-593, 2013. ,
DOI : 10.1016/j.cma.2013.09.020
of Modeling, Simulation and Applications, Cardiovascular Mathematics. Modeling and simulation of the circulatory system, 2009. ,
A computational strategy for prestressing patient-specific biomechanical problems under finite deformation, International Journal for Numerical Methods in Biomedical Engineering, vol.74, issue.1, pp.52-72, 2010. ,
DOI : 10.1186/1475-925X-6-38
Truly monolithic algebraic multigrid for fluid-structure interaction, International Journal for Numerical Methods in Engineering, vol.33, issue.2, pp.987-1016, 2011. ,
DOI : 10.1002/nme.3001
Some implementations of projection methods for Navier-Stokes equations, ESAIM: Mathematical Modelling and Numerical Analysis, vol.30, issue.5, pp.637-667, 1996. ,
DOI : 10.1051/m2an/1996300506371
An overview of projection methods for incompressible flows, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.44-47, pp.44-476011, 2006. ,
DOI : 10.1016/j.cma.2005.10.010
Stable loosely-coupled-type algorithm for fluid???structure interaction in blood flow, Journal of Computational Physics, vol.228, issue.18, pp.6916-6937, 2009. ,
DOI : 10.1016/j.jcp.2009.06.007
New development in freefem++, Journal of Numerical Mathematics, vol.20, issue.3-4, pp.251-265, 2012. ,
DOI : 10.1515/jnum-2012-0013
Fluid-Structure Interaction in Internal Physiological Flows, Annual Review of Fluid Mechanics, vol.43, issue.1, pp.141-162, 2011. ,
DOI : 10.1146/annurev-fluid-122109-160703
Abstract, Communications in Computational Physics, vol.19, issue.02, pp.337-377, 2012. ,
DOI : 10.1006/jcph.1999.6356
A Solution for the Incompressibility Dilemma in Partitioned Fluid???Structure Interaction with Pure Dirichlet Fluid Domains, Computational Mechanics, vol.195, issue.11, pp.417-429, 2006. ,
DOI : 10.1007/s00466-006-0066-5
Domain decomposition methods in computational mechanics, Computational Mechanics Advances, pp.121-220, 1994. ,
Solving large scale structural problems on parallel computers using domain decomposition techniques, pp.49-82, 1996. ,
A stable second-order scheme for fluid???structure interaction with strong added-mass effects, Journal of Computational Physics, vol.270, pp.687-710, 2014. ,
DOI : 10.1016/j.jcp.2014.04.020
Numerical Simulation of Sailing Boats: Dynamics, FSI, and Shape Optimization, Variational Analysis and Aerospace Engineering: Mathematical Challenges for Aerospace Design, pp.339-377, 2012. ,
DOI : 10.1007/978-1-4614-2435-2_15
Kinematic splitting algorithm for fluid???structure interaction in hemodynamics, Computer Methods in Applied Mechanics and Engineering, vol.265, issue.1, pp.83-106, 2013. ,
DOI : 10.1016/j.cma.2013.05.025
Balancing domain decomposition, Communications in Numerical Methods in Engineering, vol.13, issue.3, pp.233-241, 1993. ,
DOI : 10.1002/cnm.1640090307
External tissue support and fluid-structure simulation in blood flows, Biomech. Model. Mechanobiol, vol.11, pp.1-18, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00701801
An efficient preconditioner for monolithically-coupled large-displacement fluid???structure interaction problems with pseudo-solid mesh updates, Journal of Computational Physics, vol.231, issue.21, pp.7315-7334, 2012. ,
DOI : 10.1016/j.jcp.2012.07.001
Time accurate partitioned algorithms for the solution of fluid???structure interaction problems in haemodynamics, Computers & Fluids, vol.86, pp.470-482, 2013. ,
DOI : 10.1016/j.compfluid.2013.07.031
Inexact accurate partitioned algorithms for fluid???structure interaction problems with finite elasticity in haemodynamics, Journal of Computational Physics, vol.273, pp.598-617, 2014. ,
DOI : 10.1016/j.jcp.2014.05.020
An Effective Fluid-Structure Interaction Formulation for Vascular Dynamics by Generalized Robin Conditions, SIAM Journal on Scientific Computing, vol.30, issue.2, pp.731-763, 2008. ,
DOI : 10.1137/060678439
In vivo wall shear stress measured by magnetic resonance velocity mapping in the normal human abdominal aorta, European Journal of Vascular and Endovascular Surgery, vol.13, issue.3, pp.263-271, 1997. ,
DOI : 10.1016/S1078-5884(97)80097-4
Fluid-structure interactions: cross-flowinduced instabilities, 2011. ,
DOI : 10.1017/CBO9780511760792
A methodological paradigm for patient-specific multi-scale CFD simulations: from clinical measurements to parameter estimates for individual analysis, International Journal for Numerical Methods in Biomedical Engineering, vol.35, issue.6, 2014. ,
DOI : 10.1002/cnm.2692
URL : https://hal.archives-ouvertes.fr/hal-01093879
Computational hydrodynamics of capsules and biological cells, CRC Mathematical and Computational Biology, vol.20103131, 2010. ,
DOI : 10.1201/EBK1439820056
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.06, pp.957-983, 2007. ,
DOI : 10.1142/S0218202507002170
Finite elements for fluidâ??structure interaction in ALE and fully eulerian coordinates, Comput. Methods Appl. Mech. Engrg, vol.199, issue.41â??44, pp.2633-2642, 2010. ,
Evolution of the wall shear stresses during the progressive enlargement of symmetric abdominal aortic aneurysms, Journal of Fluid Mechanics, vol.560, pp.19-51, 2006. ,
DOI : 10.1017/S002211200600036X
URL : https://hal.archives-ouvertes.fr/hal-01023355
Domain Decomposition, 1996. ,
DOI : 10.1007/978-3-540-70529-1_411
Computational Methods for Parachute Fluid???Structure Interactions, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.125-169, 2012. ,
DOI : 10.1007/s11831-012-9070-4
Une m??thode d'approximation de la solution des ??quations de Navier-Stokes, Bulletin de la Société mathématique de France, vol.79, pp.115-152, 1968. ,
DOI : 10.24033/bsmf.1662
A numerical model of cellular blebbing: A volume-conserving, fluid???structure interaction model of the entire cell, Journal of Biomechanics, vol.43, issue.2, pp.210-220, 2010. ,
DOI : 10.1016/j.jbiomech.2009.09.025
