Automatic Verification of Protocols with Lists of Unbounded Length - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel automatic technique for proving secrecy and authentication properties for security protocols that manipulate lists of unbounded length, for an unbounded number of sessions. This result is achieved by extending the Horn clause approach of the automatic protocol verifier ProVerif. We extend the Horn clauses to be able to represent lists of unbounded length. We adapt the resolution algorithm to handle the new class of Horn clauses, and prove the soundness of this new algorithm. We have implemented our algorithm and successfully tested it on several protocol examples, including XML protocols coming from web services.
Fichier non déposé
hal-00918849 , version 1 (15-12-2013)
Bruno Blanchet, Miriam Paiola. Automatic Verification of Protocols with Lists of Unbounded Length. CCS'13 - ACM Conference on Computer and Communications Security, ACM SIGSAC, Nov 2013, Berlin, Germany. pp.573--584, ⟨10.1145/2508859.2516679⟩. ⟨hal-00918849⟩
Collections
INRIA INRIA2
39 Consultations
0 Téléchargements
