How network coding system constrains packet pollution attacks in wireless sensor networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Grid and Utility Computing Année : 2013
Packet pollution attack is considered as the most threatening attack model against network coding based sensor networks. A widely held belief says that, in a single source multi-destination dissemination scenario, the total number of polluted packets in the network will grow with the length of the transmission path, and the decoding failure (DF) rate at the further destination nodes are relatively lower. In this work, we first obtain an opposite result by analyzing the pollution attack in multicast scenarios, and find out a convergence trend of pollution attack by network coding system, and quantify the network resiliency against the pollution attacks which happen at any place along the source-destination paths. Then, the analysis result is proved by our simulations on two most widely deployed buffer strategies, Random-In Random-Out (RIRO) and First-in First-Out (FIFO). Finally, it is proved that RIRO has a much advanced security feature than FIFO in constraining the pollution attack gradually, and almost vanished in the end.
Fichier non déposé
hal-00918953 , version 1 (16-12-2013)
  • HAL Id : hal-00918953 , version 1
Yuanyuan Zhang, Marine Minier. How network coding system constrains packet pollution attacks in wireless sensor networks. International Journal of Grid and Utility Computing, 2013, 4 (2/3), pp.197-203. ⟨hal-00918953⟩
95 Consultations
0 Téléchargements
