Michael Lewis ? Aerodynamic Shape Optimization of Two-dimensional Airfoils Under Uncertain Conditions ? NASA, ICASE Report No, 2001. ,
Li ? Options for Robust Airfoil Optimization Under Uncertainty ? Proceedings of the 9th AIAA/ISSMO Multidisciplinary Analysis and Optimization Conference, pp.2002-5602, 2002. ,
Poloni ? Multi Objective Robust Design Optimization of Airfoils in Transonic Field, ) ? International Congress on Evolutionary Methods for Design, Optimization and Control with Applications to Industrial Problems EUROGEN 2003, 2003. ,
Pelletier ? A Sensitivity Equation Method for Fast Evaluation of Nearby Flows and Uncertainty Analysis for Shape Parameters, International Journal of Computational Fluid Dynamics, vol.20, issue.7, 2006. ,
Interactive computation and visualization towards a virtual wind tunnel, 47th 3AF Symposium on Applied Aerodynamics, 2012. ,
An optimized aerofoil parameterization for design ? Advances in Engineering Software, 2010. ,
Matsushima ? Design Performance Investigation of Modified PARSEC Airfoil Representation Using Genetic Algorithm ? Evolutionary and Deterministic Methods for Design Optimization and Control with Applications to Industrial and Social Problems, p.2011, 2012. ,
Nakahashi ? Application of PARSEC Geometry Representation to High-Fidelity Aircraft Design by CFD ? 5th, European Congress on Computational Methods in Applied Sciences and Engineering, 2008. ,
Murphy ? Global and local optimization using radial basis function response surface models, Applied Mathematical Modelling, vol.31, issue.10, 2007. ,
Obayashi ? Data Mining for Aerodynamic Design Space, Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria.fr ISSN, pp.249-6399, 2005. ,
