Real numbers, chaos, and the principle of a bounded density of information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Two definitions of the notion of a chaotic transformation are compared: sensitivity to initial conditions and sensitivity to perturba- tions. Only the later is compatible with the idea that information has a nite density.
csr.pdf (89.76 Ko) Télécharger le fichier
hal-00919543 , version 1 (17-12-2013)
Gilles Dowek. Real numbers, chaos, and the principle of a bounded density of information. CSR 2013 - 8th International Computer Science Symposium in Russia, Jun 2013, Ekaterinburg, Russia. pp.347-353, ⟨10.1007/978-3-642-38536-0_30⟩. ⟨hal-00919543⟩
Collections
INRIA INRIA2
101 Consultations
215 Téléchargements
