New interface
Conference papers
Polarizing Double Negation Translations
Abstract : Double-negation translations are used to encode and decode classical proofs in intuitionistic logic. We show that, in the cut-free fragment, we can simplify the translations and introduce fewer negations. To achieve this, we consider the polarization of the formulae and adapt those translation to the different connectives and quantifiers. We show that the embedding results still hold, using a customized version of the focused classical sequent calculus. We also prove the latter equivalent to more usual versions of the sequent calculus. This polarization process allows lighter embeddings, and sheds some light on the relationship between intuitionistic and classical connectives.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-00920224
Contributor : Olivier Hermant Connect in order to contact the contributor
Submitted on : Wednesday, December 18, 2013 - 9:30:07 PM
Last modification on : Tuesday, October 25, 2022 - 4:24:10 PM
Long-term archiving on: : Thursday, March 20, 2014 - 11:27:07 AM
main.pdf
Identifiers
  • HAL Id : hal-00920224, version 2
  • ARXIV : 1312.5420
Citation
Mélanie Boudard, Olivier Hermant. Polarizing Double Negation Translations. LPAR, Dec 2013, Stellenbosch, South Africa. pp.182-197. ⟨hal-00920224v2⟩
Share
Metrics
Record views
249
Files downloads
187
