Automated tracking and grasping of a moving object with a robotic hand-eye system, IEEE Transactions on Robotics and Automation, vol.9, issue.2, pp.152-165, 1993. ,
Visual servoing from lines, International Journal of Robotics Research, vol.21, issue.8, pp.679-700, 2002. ,
Visual servoing/tracking using central catadioptric images, Eighth International Symposium on Experimental Robotics (ISER'02), pp.863-869, 2002. ,
Vision-based control with respect to planar and nonplanar objects using a zooming camera, IEEE International Conference on Advanced Robotics (ICAR'03), pp.991-996, 2003. ,
Compensation of abrupt motion changes in target tracking by visual servoing, Proceedings 1995 IEEE/RSJ International Conference on Intelligent Robots and Systems. Human Robot Interaction and Cooperative Robots, pp.181-187, 1995. ,
DOI : 10.1109/IROS.1995.525794
Turning around an unknown object using visual servoing, Proceedings. 2000 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS 2000) (Cat. No.00CH37113), pp.257-262, 2000. ,
DOI : 10.1109/IROS.2000.894614
URL : https://hal.archives-ouvertes.fr/hal-00094976
Accurate calibration of CCD cameras, IEEE International Conference on Computer Vision and Pattern Recognition (CVPR'92), pp.96-101, 1992. ,
Using redundancy to perform a vision-based task amidst obstacles, Sixth International IFAC Symposium on Robot Control (SYROCO'00), pp.205-210, 2000. ,
Classification and realization of the different vision-based tasks, pp.199-228, 1993. ,
Visual servoing using image features defined upon geometrical primitives, Proceedings of 1994 33rd IEEE Conference on Decision and Control, pp.3782-3787, 1994. ,
DOI : 10.1109/CDC.1994.411747
Structure from controlled motion, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.5, pp.492-504, 1996. ,
Potential problems of stability and convergence in image-based and position-based visual servoing, The Confluence of Vision and Control, LNCIS, pp.66-78, 1998. ,
DOI : 10.1007/BFb0109663
URL : https://hal.archives-ouvertes.fr/inria-00352553
D visual servoing: A possible solution to improve image-based and position-based visual servoings, IEEE International Conference on Robotics and Automation, vol.1, issue.12, pp.630-635, 2000. ,
Visually guided grasping in unstructured environment, Robotics and Autonomous Systems, vol.19, pp.337-346, 1997. ,
A contour approach for image-based control on objects with complex shape, Proceedings. 2000 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS 2000) (Cat. No.00CH37113), pp.751-756, 2000. ,
DOI : 10.1109/IROS.2000.894694
Positioning a camera with respect to planar objects of unknown shape by coupling 2-D visual servoing and 3-D estimations, IEEE Transactions on Robotics and Automation, vol.18, issue.3, pp.322-333, 2002. ,
DOI : 10.1109/TRA.2002.1019462
URL : https://hal.archives-ouvertes.fr/inria-00352088
Image-based robot task planning and control using a compact visual representation, IEEE Transactions on Systems, Man, and Cybernetics - Part A: Systems and Humans, vol.29, issue.1, pp.92-100, 1999. ,
DOI : 10.1109/3468.736363
Robust model-based tracking for robot vision, 2004 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS) (IEEE Cat. No.04CH37566), pp.692-697, 2004. ,
DOI : 10.1109/IROS.2004.1389433
URL : https://hal.archives-ouvertes.fr/inria-00352025
Controller design for high performance visual servoing, Twelfth World Congress IFAC, pp.395-398, 1993. ,
A new partitioned approach to image-based visual servo control, IEEE Transactions on Robotics and Automation, vol.17, issue.4, pp.507-515, 2001. ,
Visual servoing in the task-function framework: A contour following task, Journal of Intelligent & Robotic Systems, vol.3, issue.5, pp.1-21, 1995. ,
DOI : 10.1007/BF01258305
Dynamic Stabilization of a Pan and Tilt Camera for Submarine Image Visualization, Computer Vision and Image Understanding, vol.79, issue.1, pp.47-65, 2000. ,
DOI : 10.1006/cviu.2000.0849
Visual servoing based on image motion, International Journal of Robotics Research, vol.20, issue.11, pp.857-877, 2001. ,
Application of motion-based visual servoing to target tracking, International Journal of Robotics Research, vol.20, issue.11, pp.878-890, 2001. ,
Stability and robustness of visual servoing methods, IEEE International Conference on Robotics and Automation, pp.1604-1609, 2002. ,
Visual tracking and control using Lie algebras, Proceedings. 1999 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No PR00149), pp.652-657, 1999. ,
DOI : 10.1109/CVPR.1999.784996
Three-Dimensionnal Computer Vision: A Geometric Viewpoint, 1993. ,
Visual servoing of a 6-DOF manipulator for unknown 3D profile following, Proceedings 1999 IEEE International Conference on Robotics and Automation (Cat. No.99CH36288C), pp.511-520, 2002. ,
DOI : 10.1109/ROBOT.1999.774091
Vision-based navigation and environmental representations with an omni-directional camera, IEEE Transactions on Robotics and Automation, vol.16, issue.6, pp.890-898, 2000. ,
Active filtering of physiological motion in robotized surgery using predictive control, IEEE Transactions on Robotics, vol.21, issue.1, pp.67-79, 2005. ,
Active/dynamic stereo vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.9, pp.1117-1127, 1995. ,
DOI : 10.1109/34.406652
Visual servoing of an under-actuated dynamic rigid body system: An image-based approach, IEEE Transactions on Robotics and Automation, vol.18, issue.2, pp.187-198, 2002. ,
Pose estimation from corresponding point data, IEEE Transactions on Systems, Man and Cybernetics, vol.19, issue.6, pp.1426-1445, 1989. ,
Visual Servoing: Real Time Control of Robot Manipulators Based on Visual Sensory Feedback, World Scientific Series in Robotics and Automated Systems, vol.7, 1993. ,
LQ Optimal and non linear approaches to visual servoing, [HAS 93a, pp.165-198, 1993. ,
An analytic solution for the perspective 4-point problem, Computer Vision, Graphics, and Image Processing, vol.47, issue.1, pp.33-44, 1989. ,
DOI : 10.1016/0734-189X(89)90052-2
Hand-Eye Calibration, The International Journal of Robotics Research, vol.14, issue.3, pp.195-210, 1995. ,
DOI : 10.1177/027836499501400301
Visually guided object grasping, IEEE Transactions on Robotics and Automation, vol.14, issue.4, pp.525-532, 1998. ,
DOI : 10.1109/70.704214
Versatile visual servoing without knowledge of true Jacobian, Proceedings of IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS'94), 1994. ,
DOI : 10.1109/IROS.1994.407392
Visual servoing utilizing zoom mechanism, ICRA'95), 1995. ,
Trajectory generation for obstacle avoidance of uncalibrated stereo visual servoing without 3D reconstruction, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS'95), pp.29-34, 1995. ,
A tutorial on visual servo control, IEEE Transactions on Robotics and Automation, vol.12, issue.5, pp.651-670, 1996. ,
A new formulation of visual servoing based on cylindrical coordinate system, IEEE Transactions on Robotics, vol.21, issue.2, pp.266-273, 2005. ,
Experimental evaluation of uncalibrated visual servoing for precision manipulation, IEEE International Conference on Robotics and Automation, vol.3, pp.2874-2880, 1997. ,
Visual servoing in robotics scheme using a camera/laser-stripe sensor, IEEE Transactions on Robotics and Automation, vol.12, issue.5, pp.743-750, 1996. ,
DOI : 10.1109/70.538978
Vision-Based Control in Driving Assistance of Agricultural Vehicles, The International Journal of Robotics Research, vol.38, issue.5, pp.1040-1054, 1998. ,
DOI : 10.1177/027836499801701002
Modeling, Identification and Control of Robots, Applied Mechanics Reviews, vol.56, issue.3, 2002. ,
DOI : 10.1115/1.1566397
Simultaneous determination of camera pose and intrinsic parameters by visual servoing, Proceedings of 12th International Conference on Pattern Recognition, pp.285-290, 1994. ,
DOI : 10.1109/ICPR.1994.576279
Special issue on advances in robot vision, Robotics and Autonomous System, vol.52, issue.1, 2005. ,
Autonomous 3-d positioning of surgical instruments in robotized laparoscopic surgery using visual servoing, IEEE Transactions on Robotics and Automation, vol.19, issue.5, pp.842-853, 2003. ,
DOI : 10.1109/TRA.2003.817086
Conics-based stereo, motion estimation, and pose determination, International Journal of Computer Vision, vol.10, issue.1, pp.7-25, 1993. ,
An Invitation to 3-D Vision: From Images to Models, 2003. ,
D visual servoing, IEEE Transactions on Robotics and Automation, vol.15, issue.12 2, pp.238-250, 1999. ,
D visual servoing with respect to unknown objects through a new estimation scheme of camera displacement, International Journal of Computer Vision, vol.37, issue.1, pp.79-97, 2000. ,
DOI : 10.1023/A:1008181530296
Robot control from disparate multiple sensors, International Journal of Robotics Research, vol.20, issue.5, pp.364-378, 2001. ,
Theoretical improvements in the stability analysis of a new class of model-free visual servoing methods, IEEE Transactions on Robotics and Automation, vol.18, issue.2, pp.176-186, 2002. ,
DOI : 10.1109/TRA.2002.999646
URL : https://hal.archives-ouvertes.fr/inria-00352094
Improving vision-based control using efficient second-order minimization techniques, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, pp.1843-1848, 2004. ,
DOI : 10.1109/ROBOT.2004.1308092
Using the task function approach to avoid robot joint limits and kinematic singularities in visual servoing, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS'96), pp.1083-1090, 1996. ,
Dynamic sensor planning in visual servoing, ICRA'98), pp.1988-1993, 1998. ,
Vision-based control law using 3D visual features, World Automation Congress (WAC'96), pp.497-502, 1996. ,
Robot control using monocular pose estimation, Workshop on New Trends in Image-based Robot Servoing (IROS'97, pp.1-12, 1997. ,
Central catadioptric visual servoing from 3D straight lines, IEEE/RSJ International Conference on Intelligent Robots and Systems, vol.1, pp.343-349, 2004. ,
Explicit incorporation of 2D constraints in vision-based control of robot manipulators, International Symposium on Experimental Robotics (ISER'00), pp.99-108, 2000. ,
Integrating sensor placement and visual tracking strategies, IEEE International Conference on Robotics and Automation, pp.1351-1356, 1994. ,
The resolvability ellipsoid for visual servoing, IEEE International Conference on Computer Vision and Pattern Recognition (CVPR'94), pp.829-832, 1994. ,
Strategies for increasing the tracking region of an eyein-hand system by singularity and joint limits avoidance, International Journal of Robotics Research, vol.14, issue.3, pp.255-269, 1995. ,
Visual tracking of a moving target by a camera mounted on a robot: A combination of control and vision, IEEE Transactions on Robotics and Automation, vol.9, issue.1, pp.14-35, 1993. ,
Object pose from 2D to 3D point and line correspondences, International Journal of Computer Vision, vol.15, issue.3, pp.225-243, 1995. ,
Uncalibrated dynamic visual servoing, IEEE Transactions on Robotics and Automation, vol.20, issue.1, pp.143-147, 2004. ,
Rigid and articulated motion seen with an uncalibrated stereo rig, International Conference on Computer Vision (ICCV'99), 1999. ,
Threedimensional location estimation of circular features for machine vision, IEEE Transactions on Robotics and Automation, vol.8, issue.5, pp.624-639, 1992. ,
Robot Control: The Task Function Approach, 1991. ,
Extended 2D visual servoing, IEEE International Conference on Robotics and Automation, pp.267-273, 2004. ,
Motion perceptibility and its application to active vision-based servo control, IEEE Transactions on Robotics and Automation, vol.13, issue.4, pp.607-616, 1997. ,
DOI : 10.1109/70.611333
Computation of shape through controlled active exploration, Proceedings of the 1994 IEEE International Conference on Robotics and Automation, pp.2516-2521, 1994. ,
DOI : 10.1109/ROBOT.1994.351133
Visual servoing of robot manipulators by fuzzy membership function based neural networks " , In [HAS 93a, pp.285-315, 1993. ,
Towards visually servoed manipulation of car engine parts, IEEE International Conference on Robotics and Automation, vol.4, pp.3166-3171, 1997. ,
A versatile camera calibration technique for high-accuracy 3D machine vision metrology using off-the-shelf TV cameras and lenses, IEEE Journal on Robotics and Automation, vol.3, issue.4, pp.323-344, 1987. ,
DOI : 10.1109/JRA.1987.1087109
A new technique for fully autonomous and efficient 3D robotics hand/eye calibration, IEEE Transactions on Robotics and Automation, vol.5, issue.3, pp.345-358, 1989. ,
DOI : 10.1109/70.34770
Dynamic Visual Servo Control of Robots. An Adaptive Image-based Approach, 1984. ,
Vision-based robot positioning using neural networks, Image and Vision Computing, vol.14, pp.715-732, 1996. ,
Relative end-effector control using cartesian position-based visual servoing, IEEE Transactions on Robotics and Automation, vol.12, issue.5, pp.684-696, 1996. ,
Robust 3D vision based control and planning, IEEE International Conference on Robotics and Automation, 2004. Proceedings. ICRA '04. 2004, pp.4423-4428, 2004. ,
DOI : 10.1109/ROBOT.2004.1302414
Visual station keeping for floating robots in unstructured environments, Robotics and Autonomous Systems, vol.39, issue.3-4, pp.3-4, 2002. ,
DOI : 10.1016/S0921-8890(02)00200-2
