Geometric algorithms for the intersection of curves and surfaces, Computers & Graphics, vol.19, issue.3, pp.391-403, 1995. ,
DOI : 10.1016/0097-8493(95)00009-2
A method for registration of 3-D shapes, Robotics-DL tentative, International Society for Optics and 556 ,
DOI : 10.1109/34.121791
Registration without ICP, Computer Vision and Image Understanding, vol.95, issue.1, pp.54-71, 2004. ,
DOI : 10.1016/j.cviu.2004.04.002
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.8.4316
A second order algorithm for orthogonal 561 projection onto curves and surfaces, Computer Aided Geometric, vol.562, issue.223, pp.251-260, 2005. ,
Algorithm for orthogonal projection of parametric curves onto -spline surfaces, Computer-Aided Design, vol.43, issue.4, pp.381-393, 2011. ,
DOI : 10.1016/j.cad.2011.01.008
Surface Curve Design by Orthogonal Projection of Space Curves Onto Free-Form Surfaces, Journal of Mechanical Design, vol.118, issue.1, pp.45-52, 1996. ,
DOI : 10.1115/1.2826855
Fundamentals of Computer Aided Geo- 570 metric, p.571, 1993. ,
On the curvature of curves and surfaces defined by normalforms, Computer Aided Geometric Design, vol.16, issue.5, pp.355-376, 1999. ,
DOI : 10.1016/S0167-8396(99)00003-5
Parameterization for surface fitting in re- 577 verse engineering A framework for efficient minimum 580 distance computation, Proceedings -IEEE International 581, pp.576-593, 1997. ,
Point inversion and projection for NURBS 584 curve and surface: Control polygon approach, Conference on Robotics and Automatio, pp.3678-582, 1998. ,
Distance extrema for spline models 587 using tangent cones, Proceedings of Graphics Interface 2005, pp.586-169, 2005. ,
Efficient point 590 projection to freeform curves and surfaces, in: Advances in Ge- 591 ometric Modeling and Processing, pp.589-192, 2010. ,
A coun- 599 terexample on point inversion and projection for NURBS curve, Continuous 602 point projection to planar freeform curves using spiral curves, pp.598-603, 2007. ,
Critical 605 point analysis using domain lifting for fast geometry queries, p.606 ,
A torus 608 patch approximation approach for point projection on surfaces, Computer Aided Geometric Design, vol.609, issue.265, pp.607-593, 2009. ,
Approximating curves and 611 their offsets using biarcs and pythagorean hodograph quintics, pp.610-612 ,
An example on approximation by fat arcs and fat biarcs, Computer-Aided Design, vol.38, issue.5, pp.515-517, 2006. ,
DOI : 10.1016/j.cad.2006.01.003
URL : https://hal.archives-ouvertes.fr/inria-00124253
Bisection algorithms for 617 approximating quadratic Bézier curves by G 1 arc splines, p.618 ,
A note on approximation of 620 discrete data by G 1 arc splines, Computer-Aided Design, vol.31, issue.14, pp.621-911, 1999. ,
Constrained in- 623 terpolation with biarcs, Journal of Computer Aided Design & 624 Computer Graphics, vol.19, issue.1, pp.622-623, 2007. ,
Circular spline fitting 626 using an evolution process, pp.625-423, 2009. ,
Three dimensional biarc approximation 629 of freeform surfaces for machining tool path generation, Inter- 630 national, Journal of Production Research, vol.38, issue.4, pp.628-739, 2000. ,
