Capacity-constrained point distributions: A variant of Lloyd's method, ACM Trans. Graph, vol.28, issue.86, pp.1-868, 2009. ,
Large-scale forest rendering: Real-time, realistic, and progressive, Comput. Graph, vol.36, issue.3, pp.140-151, 2012. ,
Fracture analyses using spring networks with random geometry, Engineering Fracture Mechanics, vol.61, issue.5, pp.569-591, 1998. ,
Parallel Poisson disk sampling with spectrum analysis on surfaces, ACM Transactions on Graphics, vol.29, issue.6, pp.1-16610, 2010. ,
DOI : 10.1145/1882261.1866188
Indices of individualtree competition, Modeling Forest Trees and Stands, pp.201-232, 2012. ,
Structure-aware error diffusion, ACM Trans. Graph, vol.28, issue.162, pp.1-162, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01437787
Blue noise through optimal transport, ACM Trans. Graph. 31, vol.6, issue.171, pp.1-17111, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01353135
Modelling the bivariate spatial distribution of amacrine cells, Case Studies in Spatial Point Process Modeling, pp.215-233, 2006. ,
Efficient maximal Poisson-disk sampling, ACM Trans. Graph, vol.30, issue.49, pp.1-4912, 2011. ,
Bilateral blue noise sampling: Additional algorithms and applications, 2013. ,
Progressive photon mapping, ACM Trans. Graph, vol.27, issue.130, pp.1-130, 2008. ,
Statistical Analysis and Modelling of Spatial Point Patterns, 2008. ,
Recursive Wang tiles for real-time blue noise, ACM Trans. Graph, vol.25, issue.3, pp.509-518, 2006. ,
A comparison of methods for generating Poisson disk distributions, Comput. Graph. Forum, vol.27, issue.1, pp.114-129, 2008. ,
Lp centroidal Voronoi tessellation and its applications, ACM Trans. Graph, vol.29, issue.119, pp.1-11911, 2010. ,
Anisotropic blue noise sampling, ACM Trans. Graph, vol.29, issue.167, pp.1-16712, 2010. ,
Parameterization-free projection for geometry reconstruction, ACM Trans. Graph, vol.26, issue.22, pp.1-22, 2007. ,
Analysis and synthesis of point distributions based on pair correlation, ACM Transactions on Graphics, vol.31, issue.6, pp.1-17010, 2012. ,
DOI : 10.1145/2366145.2366189
Spectral sampling of manifolds, ACM Transactions on Graphics, vol.29, issue.6, pp.1-168, 2010. ,
DOI : 10.1145/1882261.1866190
Plastic trees: Interactive self-adapting botanical tree models, ACM Trans. Graph, vol.31, issue.50, pp.1-5010, 2012. ,
Ghost SPH for animating water, ACM Trans. Graph, vol.31, issue.61, pp.1-61, 2012. ,
Diffusion based photon mapping, Comput. Graph. Forum, vol.27, issue.8, pp.2114-2127, 2008. ,
Electrostatic halftoning, Comput. Graph. Forum, vol.29, issue.8, pp.2313-2327, 2010. ,
Multiclass anisotropic electrostatic halftoning, Comput. Graph. Forum, vol.31, issue.6, pp.1924-1935, 2012. ,
Into the blue: Better caustics through photon relaxation, Comput. Graph. Forum, vol.28, issue.2, pp.319-328, 2009. ,
Photon parameterisation for robust relaxation constraints, Comput. Graph. Forum, vol.32, issue.2, 2013. ,
Progressive photon relaxation, ACM Trans. Graph, vol.32, issue.7, pp.1-7, 2013. ,
Line segment sampling with blue-noise properties, ACM Trans. Graph, vol.32, issue.127, pp.1-12714, 2013. ,
Bilateral filtering for gray and color images, ICCV '98, pp.839-839, 1998. ,
Differential domain analysis for non-uniform sampling, ACM Trans. Graph, vol.30, issue.50, pp.1-5010, 2011. ,
Gap processing for adaptive maximal Poisson-disk sampling, ACM Trans. Graph, 2013. ,
Point sampling with general noise spectrum, ACM Trans. Graph, vol.31, issue.76, pp.1-7611, 2012. ,
