Automatic rule-based checking of building designs, Automation in Construction, vol.18, issue.8, pp.1011-1033, 2009. ,
DOI : 10.1016/j.autcon.2009.07.002
An object-based 3D walk-through model for interior construction progress monitoring, Automation in Construction, vol.20, issue.1, pp.66-75, 2011. ,
DOI : 10.1016/j.autcon.2010.07.003
Path Planning and Following Algorithms in an Indoor Navigation Model for Visually Impaired, Second International Conference on Internet Monitoring and Protection (ICIMP 2007), pp.38-38, 2007. ,
DOI : 10.1109/ICIMP.2007.31
Continuum crowd simulation in complex environments, Computers & Graphics, vol.34, issue.5, pp.537-544, 2010. ,
DOI : 10.1016/j.cag.2010.05.013
BIM-based immersive evacuation simulations, 18th International Conference on the Application of Computer Science and Mathematics in Architecture and Civil Engineering, 2009. ,
A fuzzy based multi-objective path planning of construction sites, Automation in Construction, vol.13, issue.6, pp.717-734, 2004. ,
DOI : 10.1016/j.autcon.2004.04.012
Path planning in construction sites: performance evaluation of the Dijkstra, A???, and GA search algorithms, Advanced Engineering Informatics, vol.16, issue.4, pp.291-303, 2002. ,
DOI : 10.1016/S1474-0346(03)00018-1
A Guide to Building Information Modeling for Owners, Managers, Architects, Engineers, Contractors, and Fabricators, NJ, 2008. ,
Industry Foundation Classes (IFC), 2008. ,
The IFC-Compatible Implementations Database, 2011. ,
Computational algorithms to evaluate design solutions using Space Syntax, Computer-Aided Design, vol.43, issue.6, pp.664-676, 2011. ,
DOI : 10.1016/j.cad.2011.02.011
Application and extension of the IFC standard in construction cost estimating for tendering in China, Automation in Construction, vol.20, issue.2, pp.196-204, 2011. ,
BIM- and 4D-based integrated solution of analysis and management for conflicts and structural safety problems during construction: 2. Development and site trials, Automation in Construction, vol.20, issue.2, pp.167-180, 2011. ,
DOI : 10.1016/j.autcon.2010.09.014
Metrics for Quantifying the Similarities and Differences between IFC Files, Journal of Computing in Civil Engineering, vol.25, issue.2, pp.172-181, 2011. ,
DOI : 10.1061/(ASCE)CP.1943-5487.0000077
Computational Geometry: Algorithms and Applications, 2008. ,
Practical Motion Planning in Robotics: Current Approaches and Future Directions, Probabilistic Roadmaps for Robot Path Planning), 1998. ,
Map representation of a large in-door environment with path planning and navigation abilities for an autonomous mobile robot with its implementation on a real robot, Automation in Construction, vol.2, issue.2, pp.155-179, 1993. ,
DOI : 10.1016/0926-5805(93)90007-K
Planning and visualization for automated robotic crane erection processes in construction, Automation in Construction, vol.15, issue.4, pp.398-414, 2006. ,
DOI : 10.1016/j.autcon.2005.06.008
Motion planning for automated construction, Automation in Construction, vol.3, issue.1, pp.71-78, 1994. ,
DOI : 10.1016/0926-5805(94)90034-5
Automated Path Planning of Cooperative Crane Lifts Using Heuristic Search, Journal of Computing in Civil Engineering, vol.17, issue.3, pp.197-207, 2003. ,
DOI : 10.1061/(ASCE)0887-3801(2003)17:3(197)
Construction process simulation with rule-based robot path planning, Automation in Construction, vol.3, issue.1, pp.79-86, 1994. ,
DOI : 10.1016/0926-5805(94)90035-3
3D indoor navigation: a framework of combining BIM with 3D GIS, p.44, 2008. ,
Integrating BIM and gaming for real-time interactive architectural visualization, Automation in Construction, vol.20, issue.4, pp.446-458, 2011. ,
DOI : 10.1016/j.autcon.2010.11.013
Solibri Model Checker, 2009. ,
Computing the inner distances of volumetric models for articulated shape description with a visibility graph, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.12, pp.2538-2544, 2011. ,
Consideration of obstacle danger level in path planning using and Fast-Marching optimisation: comparative study, Signal Processing, vol.83, issue.11, pp.2387-2396, 2003. ,
DOI : 10.1016/S0165-1684(03)00191-9
URL : https://hal.archives-ouvertes.fr/hal-00181781
Ant Colony System Algorithm for Real-Time Globally
Optimal Path Planning of Mobile Robots, ACTA AUTOMATICA SINICA, vol.33, issue.3, pp.279-285, 2007. ,
DOI : 10.1360/aas-007-0279
On the implementation of fast marching methods for 3D lattices, 2001. ,
A fast marching level set method for monotonically advancing fronts., Proc. National Academy of Sciences (PNAS), pp.1591-1595, 1996. ,
DOI : 10.1073/pnas.93.4.1591
Level Set Methods and Fast Marching Methods, 1999. ,
Toolbox for the computation of the Fast Marching algorithm in 2D and 3D, p.6110 ,
A perfect BIM teaching case: Library of Xuzhou Institute of Architectural Technology, Architecture Technique, vol.1, pp.121-125, 2011. ,
Moving beyond the fourth dimension with an IFC-based single project database, Automation in Construction, vol.14, issue.1, pp.15-32, 2005. ,
DOI : 10.1016/j.autcon.2004.06.002
Towards distributed product data sharing environments ??? Progress so far and future challenges, Automation in Construction, vol.16, issue.5, pp.586-595, 2007. ,
DOI : 10.1016/j.autcon.2006.10.002
URL : http://usir.salford.ac.uk/615/1/Towards_distributed_product_data_sharing_environments_%E2%80%94_Progress_so_far_and_future_challenges.pdf
IFC and building lifecycle management, Automation in Construction, vol.18, issue.1, pp.70-78, 2008. ,
DOI : 10.1016/j.autcon.2008.05.001
The Building Information Modelserver (short: BIMserver) projects, p.2012 ,
MongoDB is a scalable, high-performance, open source NoSQL database, p.2012 ,
