Adaptive Task Size Control on High Level Programming for GPU/CPU Work Sharing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
On the work sharing among GPUs and CPU cores on GPU equipped clusters, it is a critical issue to keep load balance among these heterogeneous computing resources. We have been developing a runtime system for this problem on PGAS language named XcalableMP- dev/StarPU [1]. Through the development, we found the necessity of adaptive load balancing for GPU/CPU work sharing to achieve the best performance for various application codes. In this paper, we enhance our language system XcalableMP-dev/StarPU to add a new feature which can control the task size to be assigned to these heterogeneous resources dynamically during application execution. As a result of performance evaluation on several benchmarks, we confirmed the proposed feature correctly works and the performance with heterogeneous work sharing provides up to about 40% higher performance than GPU-only utilization even for relatively small size of problems.
ADPC2013-117.pdf (176.85 Ko) Télécharger le fichier
hal-00920915 , version 1 (19-12-2013)
Tetsuya Odajima, Taisuke Boku, Mitsuhisa Sato, Toshihiro Hanawa, Yuetsu Kodama, et al.. Adaptive Task Size Control on High Level Programming for GPU/CPU Work Sharing. The 2013 International Symposium on Advances of Distributed and Parallel Computing (ADPC 2013), Dec 2013, Vietri sul Mare, Italy. ⟨10.1007/978-3-319-03889-6_7⟩. ⟨hal-00920915⟩
295 Consultations
321 Téléchargements
