Static Analysis of Programs with Imprecise Probabilistic Inputs, VSTTE, 2013. ,
DOI : 10.1007/978-3-642-54108-7_2
URL : https://hal.archives-ouvertes.fr/hal-00942126
Probability and measure, 2008. ,
Better Quality in Synthesis through Quantitative Objectives, CAV, pp.140-156, 2009. ,
DOI : 10.1007/978-3-642-02658-4_14
Quantitative synthesis for concurrent programs, CAV, pp.243-259, 2011. ,
From boolean to quantitative synthesis, EMSOFT, 2011. ,
Measuring and synthesizing systems in probabilistic environments, CAV, pp.380-395, 2010. ,
Bridging boolean and quantitative synthesis using smoothed proof search, Proceedings of the 41st ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL '14, 2014. ,
DOI : 10.1145/2535838.2535859
URL : https://hal.archives-ouvertes.fr/hal-00920955
Smooth interpretation, PLDI, pp.279-291, 2010. ,
DOI : 10.1145/1806596.1806629
Smoothing a Program Soundly and Robustly, CAV, pp.277-292, 2011. ,
DOI : 10.1007/s10107-004-0552-5
Euler: A System for Numerical Optimization of Programs, CAV, 2012. ,
DOI : 10.1007/978-3-642-31424-7_57
Bayesian inference using data flow analysis, Proceedings of the 2013 9th Joint Meeting on Foundations of Software Engineering, ESEC/FSE 2013, pp.92-102, 2013. ,
DOI : 10.1145/2491411.2491423
Probabilistic Abstract Interpretation, ESOP, pp.169-193, 2012. ,
DOI : 10.1007/978-3-642-28869-2_9
Parameter Synthesis for Hybrid Systems with an Application to Simulink Models, HSCC, 2009. ,
DOI : 10.1007/978-3-540-78929-1_25
Using HyTech to synthesize control parameters for a steam boiler, Formal Methods for Industrial Applications, pp.265-282, 1995. ,
DOI : 10.1007/BFb0027241
A Note on Approximate Minimum Volume Enclosing Ellipsoid of Ellipsoids, 2008 International Conference on Computational Sciences and Its Applications, pp.478-487, 2008. ,
DOI : 10.1109/ICCSA.2008.24
Synthesis of optimal fixed-point implementations of numerical software routines, NSV, 2013. ,
Synthesis of optimal switching logic for hybrid systems, Proceedings of the ninth ACM international conference on Embedded software, EMSOFT '11, pp.107-116, 2011. ,
DOI : 10.1145/2038642.2038660
Linear-Invariant Generation for Probabilistic Programs:, SAS, pp.390-406, 2010. ,
DOI : 10.1007/978-3-642-15769-1_24
Factorie: Probabilistic programming via imperatively defined factor graphs, NIPS, pp.1249-1257, 2009. ,
Abstract Interpretation of Probabilistic Semantics, SAS, pp.322-339, 2000. ,
DOI : 10.1007/978-3-540-45099-3_17
Backwards Abstract Interpretation of Probabilistic Programs, ESOP, 2001. ,
DOI : 10.1007/3-540-45309-1_24
A simplex method for function minimization . The computer journal, p.308, 1965. ,
Termination proofs from tests, Proceedings of the 2013 9th Joint Meeting on Foundations of Software Engineering, ESEC/FSE 2013, pp.246-256, 2013. ,
DOI : 10.1145/2491411.2491413
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.353.5699
Logical Analysis of Hybrid Systems: Proving Theorems for Complex Dynamics, 2010. ,
Sciduction, Proceedings of the 49th Annual Design Automation Conference on, DAC '12, pp.356-365, 2012. ,
DOI : 10.1145/2228360.2228425
A Data Driven Approach for Algebraic Loop Invariants, ESOP, pp.574-592, 2013. ,
DOI : 10.1007/978-3-642-37036-6_31
Verification as Learning Geometric Concepts, SAS, pp.388-411, 2013. ,
DOI : 10.1007/978-3-642-38856-9_21
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.298.7748
Synthesizing data structure manipulations from storyboards, Proceedings of the 19th ACM SIGSOFT symposium and the 13th European conference on Foundations of software engineering, SIGSOFT/FSE '11, pp.289-299, 2011. ,
DOI : 10.1145/2025113.2025153
Probabilistic Abstract Interpretation of Imperative Programs using Truncated Normal Distributions, Electronic Notes in Theoretical Computer Science, vol.220, issue.3, pp.43-59, 2008. ,
DOI : 10.1016/j.entcs.2008.11.018
Program Synthesis by Sketching, 2008. ,
Program sketching, International Journal on Software Tools for Technology Transfer, vol.24, issue.1, pp.5-6475, 2013. ,
DOI : 10.1007/s10009-012-0249-7
From program verification to program synthesis, POPL, pp.313-326, 2010. ,
Deriving linearizable fine-grained concurrent objects, PLDI, pp.125-135, 2008. ,
DOI : 10.1145/1379022.1375598
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.148.1634
Abstraction-guided synthesis of synchronization Probabilistic programming with infer .NET. Machine Learning Summer School lecture notes, POPL, pp.327-338, 2009. ,
