Enabling and scaling matrix computations on heterogeneous multi-core and multi-GPU systems, Proceedings of the 26th ACM international conference on Supercomputing, ICS '12, 2012. ,
DOI : 10.1145/2304576.2304625
A Hardware Accelerator for the Fast Retrieval of DIALIGN Biological Sequence Alignments in Linear Space, IEEE Transactions on Computers, vol.59, issue.6, pp.808-821, 2010. ,
DOI : 10.1109/TC.2010.42
Productive Programming of GPU Clusters with OmpSs, 2012 IEEE 26th International Parallel and Distributed Processing Symposium, pp.557-568, 2012. ,
DOI : 10.1109/IPDPS.2012.58
StarPU: a unified platform for task scheduling on heterogeneous multicore architectures, Concurrency and Computation: Practice and Experience, vol.23, issue.4, pp.187-198, 2011. ,
DOI : 10.1002/cpe.1631
URL : https://hal.archives-ouvertes.fr/inria-00384363
XKaapi: A Runtime System for Data-Flow Task Programming on Heterogeneous Architectures, 2013 IEEE 27th International Symposium on Parallel and Distributed Processing, 2013. ,
DOI : 10.1109/IPDPS.2013.66
URL : https://hal.archives-ouvertes.fr/hal-00799904
Using dual approximation algorithms for scheduling problems theoretical and practical results, Journal of the ACM, vol.34, issue.1, pp.144-162, 1987. ,
DOI : 10.1145/7531.7535
Performance-effective and low-complexity task scheduling for heterogeneous computing, IEEE Transactions on Parallel and Distributed Systems, vol.13, issue.3, pp.260-274, 2002. ,
DOI : 10.1109/71.993206
Approximation algorithms for scheduling unrelated parallel machines, Mathematical Programming, vol.23, issue.1-3, pp.259-271, 1988. ,
DOI : 10.1007/BF01585745
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.115.708
An approximation algorithm for the generalized assignment problem, Mathematical Programming, vol.46, issue.1-3, pp.461-474, 1993. ,
DOI : 10.1007/BF01585178
An optimal rounding gives a better approximation for scheduling unrelated machines, Operations Research Letters, vol.33, issue.2, pp.127-133, 2004. ,
DOI : 10.1016/j.orl.2004.05.004
Scheduling unrelated machines of few different types, p.974, 2012. ,
A Polynomial Approximation Scheme for Scheduling on Uniform Processors: Using the Dual Approximation Approach, SIAM Journal on Computing, vol.17, issue.3, pp.539-551, 1988. ,
DOI : 10.1137/0217033
Scheduling on heterogeneous cluster environments, 2012. ,
Numerical linear algebra on emerging architectures: The PLASMA and MAGMA projects, Journal of Physics: Conference Series, vol.180, 2009. ,
DOI : 10.1088/1742-6596/180/1/012037
Grid'5000: A Large Scale And Highly Reconfigurable Experimental Grid Testbed, International Journal of High Performance Computing Applications, vol.20, issue.4, pp.481-494, 2006. ,
DOI : 10.1177/1094342006070078
URL : https://hal.archives-ouvertes.fr/hal-00684943
