Conference papers
Adaptive control for optimizing microalgae production
Francis Mairet 1 Rafael Munoz Tamayo 1 Olivier Bernard 1, 2
1 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : In this paper, we propose a nonlinear adaptive controller for light-limited microalgae culture. This controller regulates the light absorption factor, defined by the ratio between the incident light and the light at the bottom of the reactor. Then, we propose a set-point for the light absorption factor which allows to optimize biomass productivity under constant illumination. Finally, we show by numerical simulation that the adaptive controller can be used to obtain near optimal productivity under day-night cycles.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00921486
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Friday, December 20, 2013 - 2:53:33 PM
Last modification on : Saturday, June 25, 2022 - 11:12:32 PM
Long-term archiving on: : Friday, March 21, 2014 - 6:40:43 AM
File
cab-control_algae_v4.pdf
Identifiers
  • HAL Id : hal-00921486, version 1
  • PRODINRA : 281434
Citation
Francis Mairet, Rafael Munoz Tamayo, Olivier Bernard. Adaptive control for optimizing microalgae production. Computer Application in Biotechnology (CAB2013), Dec 2013, Mumbai, India. ⟨hal-00921486⟩
Share
Metrics
Record views
592
Files downloads
350
