GPU Improvements on the sorting and projection of tetrahedral meshes for direct volume rendering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Direct Volume Rendering is one of the most popular visualization techniques. Although approaches such as ray-casting or slicing are fast and well-implemented on graphics hardware for regular and irregular grids, cell projection techniques are still time-consuming for large tetrahedral meshes. We propose improvements to the pipeline of cell projection techniques based on the SXMPVO [4] and the Projected Tetrahedra [8] (PT) algorithms. Specifically, we exploit new functionalities of the latest graphics hardware to remove bottlenecks in the sorting and rendering phases.
Fichier non déposé
hal-00921795 , version 1 (21-12-2013)
  • HAL Id : hal-00921795 , version 1
Sébastien Barbier, Georges-Pierre Bonneau. GPU Improvements on the sorting and projection of tetrahedral meshes for direct volume rendering. PacificVis 2008 - Pacific Visualization Symposium 2008, Mar 2008, Kyoto, Japan. ⟨hal-00921795⟩
122 Consultations
0 Téléchargements
