A Second-Order Maximum Principle in Optimal Control under State Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Serdica Mathematical Journal Année : 2013
A second-order variational inclusion for control systems under state constraints is derived and applied to investigate necessary optimality conditions for the Mayer optimal control problem. A new pointwise condition veri ed by the adjoint state of the maximum principle is obtained as well as a second-order necessary optimality condition in the integral form. Finally, a new su cient condition for normality of the maximum principle is proposed. Some extensions to the Mayer optimization problem involving a di erential inclusion under state constraints are also provided.
RevisedFrankowskaHoehenerTonon.pdf (389.52 Ko) Télécharger le fichier
hal-00926407 , version 1 (09-01-2014)
  • HAL Id : hal-00926407 , version 1
Hélène Frankowska, Daniel Hoehener, Daniela Tonon. A Second-Order Maximum Principle in Optimal Control under State Constraints. Serdica Mathematical Journal, 2013, 39 (3), pp.233-270. ⟨hal-00926407⟩
317 Consultations
154 Téléchargements
