Rational Invariants of Finite Abelian Groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Evelyne Hubert
George Labahn
  • Fonction : Auteur
  • PersonId : 917248
We investigate the field of rational invariants of the linear action of a finite abelian group in the non modular case. By diagonalization, the group is accurately described by an integer matrix of exponents. We make use of linear algebra to compute a minimal generating set of invariants and the substitution to rewrite any invariant in terms of this generating set. We show that the generating set can be chosen to consist of polynomial invariants. As an application, we provide a symmetry reduction scheme for polynomial systems the solution set of which are invariant by the group action.
HubertLabahnAbelian2.pdf (286.85 Ko) Télécharger le fichier
hal-00921905 , version 1 (22-12-2013)
hal-00921905 , version 2 (18-01-2014)
hal-00921905 , version 3 (20-01-2014)
hal-00921905 , version 4 (21-10-2014)
  • HAL Id : hal-00921905 , version 2
Evelyne Hubert, George Labahn. Rational Invariants of Finite Abelian Groups. 2013. ⟨hal-00921905v2⟩
439 Consultations
727 Téléchargements
