Computing Puiseux series for algebraic surfaces, Proceedings of the 37th International Symposium on Symbolic and Algebraic Computation, ISSAC '12, pp.20-27, 2012. ,
DOI : 10.1145/2442829.2442837
Cutting Planes and the Elementary Closure in Fixed Dimension, Mathematics of Operations Research, vol.26, issue.2, pp.304-312, 2001. ,
DOI : 10.1287/moor.26.2.304.10555
URL : https://hal.archives-ouvertes.fr/inria-00101099
INVARIANT FIELDS AND LOCALIZED INVARIANT RINGS OF p-GROUPS, The Quarterly Journal of Mathematics, vol.58, issue.2, pp.151-157, 2007. ,
DOI : 10.1093/qmath/ham011
On the Fixed Field of a Linear Abelian Group, Journal of the London Mathematical Society, vol.2, issue.1, pp.348-350, 1969. ,
DOI : 10.1112/jlms/s2-1.1.348
Computational Invariant Theory. Invariant Theory and Algebraic Transformation Groups I, 2002. ,
On the complexity of computing gröbner bases for quasi-homogeneous systems, Proceedings of the International Symposium on Symbolic and Algebraic Computation, ISSAC '13, pp.189-196, 2013. ,
Gröbner bases of ideals invariant under a commutative group : the nonmodular case, Proceedings of the International Symposium on Symbolic and Algebraic Computation, ISSAC '13, pp.347-354, 2013. ,
Die Isomorphie der Invariantenkörper der endlicher Abelschen Gruppen linearer Transformationen, Nachr. Ges. Wiss. Göttingen, Math.-Phys. Kl, pp.77-80, 1915. ,
Zur Theorie der endlichen Abelschen Gruppen, Mathematische Annalen, vol.77, issue.1, pp.81-88, 1915. ,
DOI : 10.1007/BF01456820
Symbolic solution of polynomial equation systems with symmetry, Proceedings of the International Symposium on Symbolic and Algebraic Computation, ISSAC'90, pp.112-119, 1990. ,
Matrix Analysis, 1985. ,
Spans in the module (Z m ) s . Linear and Multilinear Algebra, pp.67-77, 1986. ,
Algebraic and Differential Invariants, Foundations of Computational Mathematics number 403 in London Mathematical Society Lecture Note Series, 2011. ,
DOI : 10.1017/CBO9781139095402.009
URL : https://hal.archives-ouvertes.fr/hal-00763310
Rational Invariants of a Group Action, Journees Nationales de Calcul Formel CEDRAM -Center for Diffusion of Academic Mathematical Journals, p.10, 2013. ,
DOI : 10.5802/ccirm.19
URL : https://hal.archives-ouvertes.fr/hal-00839283
Rational invariants of a group action. Construction and rewriting, Journal of Symbolic Computation, vol.42, issue.1-2, pp.203-217, 2007. ,
DOI : 10.1016/j.jsc.2006.03.005
Smooth and Algebraic Invariants of a Group Action: Local and Global Constructions, Foundations of Computational Mathematics, vol.7, issue.4, pp.455-493, 2007. ,
DOI : 10.1007/s10208-006-0219-0
URL : https://hal.archives-ouvertes.fr/inria-00198857
Rational invariants of scalings from Hermite normal forms, Proceedings of the 37th International Symposium on Symbolic and Algebraic Computation, ISSAC '12, pp.219-226, 2012. ,
DOI : 10.1145/2442829.2442862
URL : https://hal.archives-ouvertes.fr/hal-00657991
Scaling Invariants and Symmetry Reduction of Dynamical Systems, Foundations of Computational Mathematics, vol.12, issue.2, pp.479-516, 2013. ,
DOI : 10.1007/s10208-013-9165-9
URL : https://hal.archives-ouvertes.fr/hal-00668882
Algorithmic Invariant Theory of Nonreductive Groups, Qualitative Theory of Dynamical Systems, vol.244, issue.6, pp.79-110, 2012. ,
DOI : 10.1007/s12346-011-0059-4
Fixed fields of triangular matrix groups, Journal of Algebra, vol.302, issue.2, pp.845-847, 2006. ,
DOI : 10.1016/j.jalgebra.2006.03.037
The computation of invariant fields and a new proof of a theorem by Rosenlicht. Transformation Groups, pp.657-670, 2007. ,
Rational functions invariant under a finite abelian group, Inventiones Mathematicae, vol.28, issue.2, pp.299-325, 1974. ,
DOI : 10.1007/BF01389732
Invariants of certain groups. I. Nagoya Math, J, vol.41, pp.69-73, 1971. ,
Toric border bases, Proceedings of the International Symposium on Symbolic and Algebraic Computation, p.14, 2014. ,
Calculating generators for invariant fields of linear algebraic groups In Applied algebra, algebraic algorithms and error-correcting codes, LNCS, vol.1719, 1999. ,
Characterizing separating invariants, 2010. ,
A Neural Network Modeled by an Adaptive Lotka-Volterra System, SIAM Journal on Applied Mathematics, vol.49, issue.6, pp.1779-1792, 1989. ,
DOI : 10.1137/0149109
Gr??bner Bases for Ideals in Laurent Polynomial Rings and their Application to Systems of Difference Equations, Applicable Algebra in Engineering, Communication and Computing, vol.9, issue.4, pp.271-291, 1999. ,
DOI : 10.1007/s002000050108
Invariant Theory, Algebraic geometry. IV, Encyclopedia of Mathematical Sciences, 1994. ,
Theory of Linear and Integer Programming, 1986. ,
Linear Representations of Finite Groups, Graduate Texts in Mathematics, vol.42, 1996. ,
DOI : 10.1007/978-1-4684-9458-7
Algorithms for Matrix Canonical Forms, 2000. ,
Asymptotically fast computation of Hermite normal forms of integer matrices, Proceedings of the 1996 international symposium on Symbolic and algebraic computation , ISSAC '96, pp.259-266, 1996. ,
DOI : 10.1145/236869.237083
Fast Algorithms for Linear Algebra Modulo N, Algorithms ESA'98, pp.139-150, 1998. ,
DOI : 10.1007/3-540-68530-8_12
Algorithms in Invariant Theory. Texts and Monographs in Symbolic Computation, 1993. ,
Invariant rational functions and a problem of Steenrod, Inventiones Mathematicae, vol.2, issue.2, pp.148-158, 1969. ,
DOI : 10.1007/BF01389798
